Old 05-01-2026, 09:14 PM   #1
RalphM
RalphM's Avatar
Default Long time no see! 47 splash pan ?
Hello again, I probably have to do a “new member” thread I’ve been gone so long.
Life&work got in the way, I finally retired and I am pushing on with the 47 coupe.
I have a question about the lower radiator splash pan. I’m not sure if I have it on correctly, or if I have the rubber strip correctly installed on it.
My Ford books don’t show that in very good detail.
Thank you,
Ralph
P.S. I hope I can visit more often now that I’m retired.
RalphM is offline   Reply With Quote
Old 05-01-2026, 10:51 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Long time no see! 47 splash pan ?
Thank you,
Ralph
Old 05-02-2026, 04:59 AM   #3
flathead48
If yours is a late 47 it will be the same as my 48. The hole for radiator drain is the horizontal position & the the angle part with rubber strip goes against radiator. Hope this helps
flathead48 is offline   Reply With Quote
Old 05-02-2026, 09:44 AM   #4
RalphM
RalphM's Avatar
Here’s a top view.
Old 05-02-2026, 10:24 AM   #5
petehoovie
petehoovie's Avatar
Here’s a top view.
