Old 04-24-2026, 06:46 PM   #1
larry harding
Default input ahaft repair
i was just watching one of john karel's video on tranny repair. he mentioned that the worn end of the input shaft could be repaired by sleeving. at nearly $200 for a new shaft, that sounds like a good idea. the snout that goes in the pilot bearing is not very hard and could be easily turned down. if any one has done this i'd like some pointers. i've got an old shaft or two i could practice on. practice on. thanks for suggestions.
larry harding is offline   Reply With Quote
Old 04-24-2026, 08:31 PM   #2
Bob C
Default Re: input ahaft repair
There was a thread some years back with the part number for a bearing with the same OD of the pilot bearing but the ID was smaller.
Found the thread, go to post #9 in the link.
https://www.fordbarn.com/forum/showt...+pilot+bearing
Old 04-25-2026, 12:46 PM   #3
J Franklin
J Franklin's Avatar
A guy once was selling this setup at the Portland swapmeet a few years back. He said it was a metric sized bearing.
Old 04-25-2026, 02:41 PM   #4
Bob C
The pilot bearing is metric. ID 17mm, OD 40mm,
W 12mm. The bearing with the smaller ID is 15.875 mm
or 5/8".
Old 04-25-2026, 06:51 PM   #5
Bigsnapper43
I'v done this repair as per the article. The bearing race is a Torrington, If you do'nt find the article give me a call. 740 658 3495
Bigsnapper43 is offline   Reply With Quote
Old 04-25-2026, 11:32 PM   #6
Synchro909
Synchro909's Avatar
I've sleeved a worn input shaft to take the correct 17mm ID bearing. Easy and back to original - perfect!
BTW, all of the bearings in the Model A gearbox and I suspect the differential too are metric. A couple of years ago, I took apart an original gearbox and noted that all of the bearings were made in Italy.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 04-26-2026, 04:21 AM   #7
Bob Bidonde
Bob Bidonde's Avatar
This slide depicts what I do to repair the transmission input shaft. This fix works and I have thousands of miles on the last one I did.
File Type: jpg Transmission – Pilot Bearing Journal Wear Fix akb.jpg (80.3 KB, 67 views)
Bob Bidonde
Old 04-26-2026, 05:38 AM   #8
Bruce of MN
Bruce of MN's Avatar
How do you assure concentricity without turning the jb weld down in a lathe?
Old 04-26-2026, 10:24 AM   #9
Fullraceflathead
Fullraceflathead's Avatar
You really can't accurately do that it needs to be in a lathe or on V. blocks!!!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 04-26-2026, 03:08 PM   #10
Joe K
Joe K's Avatar
I've done this with a short piece of 3/8" seamless pipe from the power plant.
You ream out the inside of the pipe to a standard size. (As pipe is made its not too uniform in wall thickness or concentric between outside and in.)
Then you turn the input shaft stub end to give about 1.5 thousandths INTERFERENCE FIT. Maybe give the stub a half a thousandths taper to ease going on.
Then you press it on bathing liberally with Locktite No. 243 formerly "red" loctite. See https://next.henkel-adhesives.com/us...eadlocker.html
Let it "set" overnight. Then holding the shaft between centers, turn the od of the stub/pipe to be a "strong fit" in the new bearing. I've "knurled" the fit once which requires the shaft stub to be tapped in with a hammer - but assures that the bearing moves in the flywheel and not the shaft stub in the bearing. I suspect "tight" would be good enough and much like the original.
Joe K
Shudda kept the horse.
Old 04-27-2026, 10:59 AM   #11
Fullraceflathead
Joe K. has the right idea using The input shaft in between centers will produce perfect concentricity
-Henry Ford
1941 Willy's Pickup
Old 04-27-2026, 11:05 AM   #12
katy
katy's Avatar
6203-16-2rs
katy is online now   Reply With Quote
