Old 04-24-2026, 07:42 PM   #1
Fibber Mcgee
Fibber Mcgee's Avatar
Default 1949 F1 drum swap
I've seen the threads about using 1980s Bronco rear drums as a front drum replacement. Is there any issue with the center hole size? I read F1 drums use the hub to center the drums.
Would Ac Delco 18B33 drums work?
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 04-25-2026, 06:09 AM   #2
rich b
rich b's Avatar
Default Re: 1949 F1 drum swap
Hub register on the Bronco drums match the pilot on an F-1 hub.
Old 04-25-2026, 07:38 AM   #3
Fibber Mcgee
Thanks. Seems like the best alternative to finding F1 drums. Mine are right at .060 over.
Old 04-25-2026, 10:24 AM   #4
petehoovie
petehoovie's Avatar
Old 04-30-2026, 02:53 PM   #5
ClutchDumpinDan
Oh wow, first I've heard of this. Is it a direct swap? Hard to find anyone to turn drums around me anymore.
ClutchDumpinDan is offline   Reply With Quote
Old 04-30-2026, 04:04 PM   #6
rich b
rich b's Avatar
Yes, they are.
80 Bronco [U]rear[U] is a good application to use.
Being "flat faced" they differ in appearance from the originals; but once a wheel is on, it isn't seen.
Initial anchor pin adjustment has to be done differently due to the lack of feeler gauge slots; but drums with slots haven't been made in forever.
If you come across full cast iron F-1 repop drums, be aware that they are known for casting shift and uneven balance.
Talking F-1 front drums above.
F-1 rears are still available in the regular automotive market.
