Old 04-10-2026, 09:22 AM   #1
51woodie
51woodie's Avatar
Default Wheel Bearing Lubricant
Starting preseason service on my '46 Super Deluxe Coupe. When I bought the car, I cleaned and packed the front and rear bearings with CRC SL3131 grease. I now have 7500 miles since the job was done, and I'm questioning if I need to repack the wheel bearings.
Questions: Do I need to repack at 4500 miles?
Is the leftover half can from seven years ago, still useable?
If not useable, is there a recommended substitute?
Because SL3131 grease is sodium-based, it is highly incompatible with modern lithium-complex or aluminum-complex greases.
51woodie is offline   Reply With Quote
Old 04-10-2026, 12:36 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Wheel Bearing Lubricant
If the 7 year old grease has been kept in a sealed can and kept clean it should be good to use. I would only use compatible grease or clean all the old off before using another base grease.
Old 04-12-2026, 01:02 AM   #3
acchaplin
So you guys say that this CRC SL3131 drum brake wheel bearing grease is better than say,,,,,, that Lucas Red 'n Tacky stuff?
acchaplin is offline   Reply With Quote
Old 04-12-2026, 01:29 AM   #4
J Franklin
J Franklin's Avatar
Why not use what you have and decide later?
Old 04-12-2026, 01:43 AM   #5
acchaplin
Not sure I understand your statment to the question I asked.
Out of the two greases, Lucas Red 'n Tacky, and the Stay Lube CRC SL3131. Which is the better for brake drum wheel bearings? Thanks
Old 04-12-2026, 09:31 AM   #6
tubman
tubman's Avatar
Since I've never had a wheel bearing in anything fail in the last 75 years of doing this, I'd say it's all good.
Old 04-12-2026, 04:36 PM   #7
Flathead Fever
Flathead Fever's Avatar
I was a fleet mechanic for 30-years and packed more wheel bearings then I want to think about. 300 to 400 trucks and every 30K miles they got packed. We bought 15-gallon barrels of Chevron wheel bearing grease. The important thing is to not mix up the types of grease. If you're unsure what was used the last time, you need clean the bearings and inside of the drum with brake clean, so the new brake grease is not contaminated with the old stuff.
Flathead Fever is online now   Reply With Quote
Old 04-12-2026, 11:53 PM   #8
J Franklin
J Franklin's Avatar
The Stay Lube CRC SL3131 is made as a wheel bearing grease. I don't know anything about the advertised uses of the Lucas grease.
Old 04-13-2026, 05:44 AM   #9
1952henry
1952henry's Avatar
Red n Tacky can be used as a wheel bearing grease. As stated, go with what is already in the bearings, unless you want to thoroughly clean everything. Your can of CRC grease should be fine, unless it sat uncovered, getting exposed to dirt, dust or rain.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 04-13-2026, 07:04 PM   #10
Oldcarbearings
Location: North Warrandyte, Melbourne,Victoria, Australia
We recommend&sell TIMKEN wheel bearing grease ......., WHAT BETTER quality/type of grease from the company that makes bearings?!......
Oldcarbearings is offline   Reply With Quote
Old 04-14-2026, 09:14 AM   #11
51woodie
51woodie's Avatar
The Timken grease you suggest is good stuff, but it is lithium based, which is not compatible with the sodium based grease that is in the bearings now. I have no worries changing to the Timken grease, but that means I would have to pull the grease seals, that usually get destroyed in the removal, to be able to clean the bearings and hubs. I guess I'll have to order some seals.
Old 04-14-2026, 10:47 AM   #12
petehoovie
petehoovie's Avatar
Old 04-14-2026, 06:51 PM   #13
Flathead Fever
That red wheel bearing grease is some super good stuff. Even after 30K miles the bearings look good and are full of grease. That red grease sticks to the bearings. We were using the old-fashioned chassis lube grease at work, and we would lose wheel bearings occasionally, 400 vehicles in the yard. We switched to the red grease, and I don't think we ever lost another wheel bearing again. But you do need to clean out all of the old green grease, so the new red grease is not contaminated with it.
Old 04-15-2026, 07:40 AM   #14
Tim Ayers
I came here to say I bought a can of Timken wheel bearing grease a few months back using the same logic as you.
Old 04-15-2026, 07:33 PM   #15
Oldcarbearings
Despite an incorrect comment about the kind/type of grease TIMKEN THEMSELVES list/mention it as being suitable for both DRUM&DISC brakes....... straight from the horses mouth!......, you CAN'T USE GREY colored grease (same grease used for chassis/steering/suspension components) in wheel bearings because of the heat......It also defys logic/rationale/reason WHY OEM would recommend/suggest that/this kind/type of grease for lubricating king pin bearings in 4WD/4X4 as soon as you go through a creek or river the grease will wash out!....... SMH SIGH .
Old 04-15-2026, 07:50 PM   #16
Tim Ayers
So I opened my can of Timken grease today. Without getting it sent out to be analyzed, it sure looks a lot like Lucas Red & Tacky.
Old 04-17-2026, 10:21 AM   #17
51woodie
51woodie's Avatar
I looked in the half can of SL3131 that I had left over from initial use, and there is no sign separation, so I will repack with what I have. I guess next time it will be more work to do "Red and Tacky".
Thank you all for your comments.
Old 04-17-2026, 04:41 PM   #18
1952henry
1952henry's Avatar
Im guilty of delving into grease trivia, but end of day, did previous owners ( when these were main forms of transportation) give two thoughts about what grease they used, if grease was used at all?
Old 04-18-2026, 08:25 PM   #19
325w
At a local service station back in early 70’s they decided it was easier to use the chassis lube gun to pack wheel bearings. They had lots of wheel bearings to replace.
325w is offline   Reply With Quote
Old 04-19-2026, 10:32 AM   #20
Planojc
Planojc's Avatar
From what I've read, the Stay Lube CRC SL3131 is no longer available.
Planojc is offline   Reply With Quote
