Old 03-25-2026, 08:12 AM   #1
GLAmes
GLAmes's Avatar
Default Re: '56 rebuilt steering box.....
Pull it out from under the dash, through the hole in the floorboards created when you remove the two clamshell covers. The steering wheel would probably hit the headliner if not removed.
'54 Skyliner. As close to original as I could restore it to.
GLAmes is offline   Reply With Quote
Old 03-25-2026, 08:47 AM   #2
51504bat
51504bat's Avatar
There is a guy on the HAMB NealinCA that has a good rep for early Ford box rebuilding. Not sure if he does '56 boxes but might be worth a contact. JMO
51504bat is online now   Reply With Quote
