I am looking for the proper procedure for fixing the pin in the coupler mating the pinion shaft to the driveshaft on my 39. I have read that this is done by staking the coupler around the pin. But when I removed the pin, the pin had been peened over the coupler.
Which technique is correct? |
Pin gets peened over the coupler.
10 years ago I replaced one pin with a 1/4-28 nut and bolt. I applied a thin layer of solder over the shank of the bolt, tapped it through the hole so it was a very tight fit all around
(unlike the replacement) , installed the nut with Locktite and peened the end of the bolt over the nut. So far so, good. The reason I did this was because I didn't think it would be possible to swedge the replacement pin sufficiently so it would expand and tightly fill the hole. The excess solder was sheared off filling the hole when the bolt was hammered into position. The red thing is a seal to prevent rear end fluid from draining down the torque tube to the torque tube center bearing. Last edited by 19Fordy; 03-23-2026 at 08:27 PM. |
Caution about pinion bearing taking hammer load. I put an anvil under the pin when hammer swedging it. Newc - When peaning or hammering the pin watch your bearing load. Newc
Newc, are you on team stake the coupler hole; or peen the pin?
Mart. |
Mart: Thanks for posting the info. on Jubilee Clips. I wasn't aware of them.
#8 | |
Last time I found discussion here and got a piece of heavy wall shrink tubing as explained in this link:
https://www.fordbarn.com/forum/showp...89&postcount=8
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat’s Notes Techno Source for the 1932 thru 1953 Flathead Ford |
There's also an aftermarket safety deal, a strap goes halfway around the shaft. Holes are in both ends for the pin to go thru the pin is peened on the out side, Thusly, if the pin is sheered, the strap holes the parts of the pin from getting out.
Karl |
Be careful on peeing over not to keep going too long smacking at it as it will just weaken the head. Also a pic showing the heat shrink sleeve I use.
"Came too close to dying to stop living now!" |
#13 | |
#14 |
hose clamp/jubilee clip yeh it will hold it but it would induce a wicked vibration as it spun be like sticking wheel weights to a tail shaft
#15 |
Mart told of using a second hose clamp 180˚ out for balance. post #6.
Alan |
#16 |
I like the heatshrink tubing idea. Can anyone feed back on how it holds up after many years in use?
Mart. |
#17 |
Yeah Mart, it’s permanent. If you ever need to remove it, you’ll need to cut it off. Not only does it shrink into place, it glues itself too.
#18 |
What a great tutorial ! This information cannot be found in a repair manual. Preserved on this site for folks long after most of us are gone. I am always amazed and appreciative of the sharing of knowledge from all of the FordBarn gurus! No question goes unanswered!
#19 | |
Alan |
| Thread Tools | |
| Display Modes | |
