Old 03-22-2026, 10:57 AM   #1
Andy
Default Stock block cam Bering hole diameter?
My 32 block was bored to use cam bearings. I would like to know the stock diameter of the holes. The new bearings were too tight. I suspect the bores are undersized.
Thanks!
Andy is offline   Reply With Quote
Old 03-22-2026, 11:20 AM   #2
19Fordy
19Fordy's Avatar
Default Re: Stock block cam Bering hole diameter?
Here's some info.
https://www.bing.com/search?q=cam+be...ANAB01&PC=HCTS
Old 03-22-2026, 01:05 PM   #3
petehoovie
petehoovie's Avatar
Originally Posted by 19Fordy View Post
3 1/16 inches
The bore size of the 1932 Ford V8 engine is 3 1/16 inches, and the stroke is 3 3/4 inches, resulting in a total displacement of 221 cubic inches. The main bearings are 1.998 to 1.999 inches in diameter.
Old 03-22-2026, 03:18 PM   #4
Ronnieroadster
Ronnieroadster's Avatar
The 1932 Ford block did not have cam bearings the cam which was steel rode directly in the iron bore of the block. The cam bearing journal diameter on Ford flathead V-8 cams from 1932 to 1953 is 1.7955. The 1932 Ford block bore diameter for the steel cam would be a few thousands larger than the 1.7955 dimension so it would not seize up in the block bore.
Cam bearings were installed in Ford flathead V-8 engine blocks beginning in 1933 and continued to the end of production in 1953 the block bore diameter for the cam bearing's remained the same during this production run.
A cam bearing set is available with an additional plus .010 this cam bearing set would be used when worn cam shaft journals were ground .010 undersize to help save the cam.
To help answer the original posters question measure the Cam bearing diameter if you find it is below the 1.7955 than there's certainly a problem. If you find the bore diameter measures .010 under the 1.7955 the cam bearing's are the undersize set.
If the block was bored undersize for a new set of cam bearings it would have been extremely difficult to force in a new set of bearings.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 03-23-2026, 10:49 PM   #5
Bored&Stroked
Bored&Stroked's Avatar
Hey Ronnie, the cam bearings you're speaking of are for a cam that has been ground .010 on the bearing journals - like original Potvin 425's on 32 billet cores.
I don't believe they are related to the OD of the bearing and block? Are you saying there is another set of CAM bearings that are .010 under on the OD (block bore)?
I've never seen that. I have seen some that are LARGER on the OD . . . probably to fix blocks that were screwed up during initial manufacturing.
Old 03-24-2026, 07:25 PM   #6
Ronnieroadster
No Dale the dimension's I wrote 1.7955 is the stock Cam bearing journal dimension's of the camshaft. Then I added the information that maybe someone installed the .010 under cam bearings made for a cam that's been ground .010 under on its cam bearing journals such as the 32 steel steel cam.
Not anything written about the block bore diameter for the cam bearings just what the cam bearing journals would measure and thus the cam bearings ID .
Old 03-25-2026, 08:49 AM   #7
Bored&Stroked
Thanks Ronnie . . . was just having an issue in understanding what you were saying. I'm on the same page with you on the .010 undersize on the ID of the bearing - have used them multiple times and always keep a spare set in case I need them in the future.
