#21 | |
Rich |
#22 |
Dashman's is the only one I am aware of that makes the phenolic spacers.
https://www.ebay.com/str/dashmanshotrodandspeedparts If you are crafty you can make one out of plywood using a gasket as a template, its basically the same thing. But their prices are so low I have bought several from them rather than make one. |
#23 | |
Rich |
#24 |
the hole in a cog will expand in size when heated is what i keep in mind when dealing with objects stuck on a metal rod. it's important to know too, that the rod will also expand when heated. so's best to try to direct the heat to the cog rather than the rod. it's how the ring gear was put on my flywheel about half a century ago.
here's a brief explanation as to why... A hole in a cog (or any metal object) expands when heated because the metal atoms vibrate more intensely, forcing them to move farther apart from each other. This, known as thermal expansion, causes the entire object—including the boundaries of the hole—to expand uniformly outwards, increasing its size. Last edited by hueyhoolihan; 03-18-2026 at 01:20 PM. |
#25 | |
I put in the new fuel line and started the Ford up..... I still see bubbles in the fuel line from the fuel pump to the carb. I also tried to tighten the fuel pump diaphragm bolts (maybe 1/8 turn). Still see air bubbles in the fuel line. I am leaning towards an electric fuel pump.
Rich |
#26 |
#27 |
Hello 'rbassemir',
RE: "So, Scubachief, You had the electric fuel pump in line with the mechanical fuel pump? So when you had the electric fuel pump off, the mechanical pump was strong enough to suck gas through the electrical pump when it was not running?" I installed a Flow Thru type 6 volt electric fuel pump... and with it in your hand, preinstalled, you can easily blow air thru it.. and fuel easily flows thru without restriction too. The original rebuilt mechanical fuel pump has no issues at all pulling in the fuel. I might add that I replaced the fuel tank and the fuel lines as part of the very first upgrades when I began my restore. Hope this helps. Take care! |
#28 |
I relearned... that it helps to pump the accelerator pedal three or four times prior to cranking. I recalled in the old days I had to do this with my 1965 Buick Skylark and read that in a post on this site a few years back and on then recalled having to do that in the old pre-fuel injection days. Give that a try as well.
#29 | |
bad news is that also permitted the flooding of the engine with little effort if applied with too much enthusiasm.
#30 | |
Scubaking also used an electric fuel pump but I don't know his set up left the mechanical pump in line with the electric fuel pump. He said he toggles the electric fuel pump on / off manually as needed if the engine sputters. So I am guessing he leaves the mechanical pump in line.
Rich |
#31 |
Thanks Scubacheif, I missed your earlier replay.
Rich Last edited by rbassemir; 03-21-2026 at 03:14 PM. Reason: typo |
#32 |
great input Flathead Fever ... I will have to check to see if the one I bought is open.
Rich Last edited by rbassemir; 03-21-2026 at 03:18 PM. Reason: typo |
#33 |
Good evening,
I do still have the mechanical fuel pump installed... and it is inside the engine compartment so that it is mostly pulling fuel vs. pushing fuel. I have the flow thru type 6 volt electric pump installed so it is situated between the tank and the mechanical fuel pump. It is also a low pressure type pump and I seem to recall it is no stronger than 5 psi. It makes sense to have the electric fuel pump installed in the fuel line closer to the fuel tank since it pushes better than it pulls the fuel... but mine is within 18 inches of the mechanical pump and has worked just fine pulling fuel. I control the electric pump from a toggle switch mounted under the dash within easy reach of my right hand should i need it while on the road. I was waiting at a road construction hold-up the summer before last... before I had mounted the phenolic spacer [ https://nystromperformance.com/produ...p-adapter-copy ]. Engine stuttered and shut down. Vapor lock. I powered up the electric pump which apparently re primed the carburetor and with just a bit of cranking I was able to get the old gal running and decided to turn around and go another way. Point is that the electric pump saved my trip that time for sure. Now with the electric pump installed and with the phenolic spacer isolating my Holley 94 carburetor from manifold heat, i have not had a single other issue. Now I do use pure gasoline with is less prone to vapor lock over ethanol blends I am advised. This setup removes a lot of stress such as the stress of having a great breakfast with my wife... and then getting back into the old gal for the ride home only to have it not fire up. That happened a few times before I made all of the upgrades mentioned above. Another great upgrade was ditching the standard lead acid 6 volt battery for a optima red top battery. Hope this helps in your decision making... and all on this forum weigh in if you see anything else I should do to improve my old gal.
| Thread Tools | |
| Display Modes | |
