Old 03-15-2026, 12:06 PM   #21
Mart
Mart's Avatar
Default Re: 1941 pickup 4-speed speedometer gears
Thinking about it further the gear needs to be all the way back so it keeps the roller bearing located properly in the torque tube. It might be best to bite the bullet and pull the rear back and fit a good fresh circlip.
Old 03-15-2026, 12:52 PM   #22
glennpm
glennpm's Avatar
I would try using a short piece of copper wire 12 or 10 AWG NMB, i.e., household wire. You want the wire to stand proud of the slot. 12 AWG would be easier to twist the ends of and then bend the cut ends up toward the universal joint. Use a drift pin to help bend the twisted ends forward. Looks to me that there is enough space to do it and sure easier than pulling the rear-end back.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
glennpm is online now   Reply With Quote
Old 03-15-2026, 02:20 PM   #23
Kube
Super Moderator
Kube's Avatar
Here's a photo of the proper clip. It is about .087" diameter wire.
504d, I don't have any "21" assemblies. Sorry. Plenty of 17, 18, 19, but not a single 21.
Old 03-15-2026, 04:46 PM   #24
Bob C
Bert's has a nylon 21 tooth gear only.
https://www.mikes-afordable.com/product/A17272E.html
Old 03-15-2026, 05:21 PM   #25
petehoovie
petehoovie's Avatar
Code: A17272E
Model Year: 1930 - 1931
UOM: Each
Quantity in Basket: None
Price: $17.00
Quantity:
Old 03-15-2026, 06:25 PM   #26
504d
504d's Avatar
I saw this, but it says 1930-31. Would it still fit? Seems like a good idea.
1941 Ford 1/2 Ton pickup w 4-speed trans
504d is offline   Reply With Quote
Old 03-15-2026, 09:56 PM   #27
Bob C
I said Bert's but I put the link to Mike's. Bert's says it fits 20 and 21 tooth housings 1928-48. https://modelastore.com/speedometers?product_id=6875
Old 03-16-2026, 12:23 AM   #28
petehoovie
petehoovie's Avatar
A-17271-E 21 Tooth Nylon Speedometer driven - $15.00
Old 03-16-2026, 01:36 PM   #29
Brian
Brian's Avatar
one other observation; looks pretty dry in there; should be full of lube....
