#21 |
Thinking about it further the gear needs to be all the way back so it keeps the roller bearing located properly in the torque tube. It might be best to bite the bullet and pull the rear back and fit a good fresh circlip.
#22 |
I would try using a short piece of copper wire 12 or 10 AWG NMB, i.e., household wire. You want the wire to stand proud of the slot. 12 AWG would be easier to twist the ends of and then bend the cut ends up toward the universal joint. Use a drift pin to help bend the twisted ends forward. Looks to me that there is enough space to do it and sure easier than pulling the rear-end back.
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat’s Notes Techno Source for the 1932 thru 1953 Flathead Ford |
#23 |
Super Moderator
Here's a photo of the proper clip. It is about .087" diameter wire.
504d, I don't have any "21" assemblies. Sorry. Plenty of 17, 18, 19, but not a single 21.
#24 |
Bert's has a nylon 21 tooth gear only.
https://www.mikes-afordable.com/product/A17272E.html |
#25 | |
Code: A17272E Model Year: 1930 - 1931 UOM: Each Quantity in Basket: None Price: $17.00 Quantity:
#26 |
1941 Ford 1/2 Ton pickup w 4-speed trans |
#27 |
I said Bert's but I put the link to Mike's. Bert's says it fits 20 and 21 tooth housings 1928-48. https://modelastore.com/speedometers?product_id=6875
#28 | |
![]() A-17271-E 21 Tooth Nylon Speedometer driven - $15.00 |
#29 |
one other observation; looks pretty dry in there; should be full of lube....
| Thread Tools | |
| Display Modes | |
