I have a 35 woodie with 40 spindles and Lockheed brakes. My plan is to move to 53-56 bendix FRONT brake using F100 backing plates and drums. Assembling those parts now. While I am doing that, I am also planning to add a booster to my system. Car is currently outfitted with a dual master. It appears that I have two options for a booster.. a 55-57 Tbird midland or a VH44 big bore ¾” .. while chinese VH44 are available on eBay the bore is 5/16” and look to service 10” drums. Research suggests the VH44 as a better choice than the Tbird, since Tbird could be too “aggressive” . It also looks like I will need a space to run my 35 wire wheels and possible a change of wheel bearing (More info needed )
I am writing for any comment from folks who have done something similar. Flatheadfan has posts of his Tbird set up, but he is not with us now. |
I have a Midland unit with disks on front and drums on the rear. My master cylinder bore is 1". It works wonderfully for my '40. I have a pressure regulator for the rear drums to prevent premature rear brake lockup.
I also bought a VH44 which has about the same diaphragm diameter as the Midland unit. Jury is out on how well it works until the weather gets better here. "PBR VH40 Booster PBR VH40 Remote Brake Booster Designed to considerably reduce brake pedal effort without losing control of the brake application. Suitable for Disc Front/Drum Rear brakes. It is a Vacuum-Hydraulic Unit for power braking which utilizes intake manifold vacuum and atmospheric pressure for its operation. This booster is larger in diameter and generally more powerful than the VH44 and is available in many models to suit both disc and drum applications. PBR VH44 Booster Ideal for applications where a factory engine bay-mounted booster cannot be used due to space restraints. It is a Vacuum-Hydraulic Unit for power braking which utilizes intake manifold vacuum and atmospheric pressure for its operation. The VH44 is suitable for Drum brakes all round and is available in many models to suit both disc and drum applications." This is a post I made not long ago about these boosters. Read the attachments too. https://www.fordbarn.com/forum/showp...82&postcount=6
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat’s Notes Techno Source for the 1932 thru 1953 Flathead Ford |
Glenn .. thanks for the reply..
I did read through a LOT of posts ,, and found you PDF file.. so thanks for that too! I got a price from White Post (who bought out Ed) for the Midland for $595. OR i can get a new PBR vh44 out of Australia for about $400 including shipping. The VH44 has a 3/4" bore. The generally available VH44 (chinese) from Ebay have a 5/16" bore.. Cheap at 64$. but could prove to be "undersized" I will be installing a JEGS vacuum canister to be sure that I have plenty of Vacuum.. my 59AB has an ISKY 77 B cam that may draw down vacuum. So I am currently researching to see if one is "better" than the other. One thing for sure tho is that I will be using wilwood proportioning valve to assure the I can balance the system. As noted I have a dual Master .. don't remember the manufacturer, but it is a very common unit. My 40 brakes are all stock lockheed. I operate the system with stock 35 pedals and the mechanical brake crossbeam arm. Master is mounted midships BTW I am in Old Orchard Beach. |
#4 | |
#5 | |
With the integral-type units, the diaphragm works directly on the piston of the master cylinder, but with the multiplier types we are concerned with here, the power brake unit has its own hydraulic cylinder. Mounted away from the master cylinder, the multiplier is connected to the master cylinder by a hydraulic line. The diaphragm works the piston of its “slave” cylinder, which in turn is connected by a line to the wheel cylinder junction fitting on the frame, and the slave cylinder adds the necessary extra braking pressure to the wheels. When the brake pedal is held at a steady position, pressures on the diaphragm are equalized by a control valve, slowing down the assist action so you don’t lock up the wheels every time you step on the binders.
#6 | |
I thought all the stock '57 Birds used the Midland unit which only has one inlet and one outlet?
Oh, I never have a problem with the booster being too aggressive. It operates just like any other power brake system in my experience.
The VH44 has DIN type of brake line threading. These require a "bubble type" brake line end versus the SAE double flare. I found that I could not get a leak tight joint for one of the DIN fittings. I re-threaded a 1/8 NPT by 3/6 male inverted flare fitting so the 1/8 NPT was changed to a 3/16-24. I used blue Loctite threaded into the VH444 and problem was solved. |
Glenn I have vacuum plate that will sit under my 97 carb
I was also thinking about using the vacuum canister to feed my vacuum Trico wiper... Also, do you have any info on the chinese units... effectiveness, capabilities, et.c |
As posted by 'glennpm':
#10 | |
I can't comment on function for the VH44 however, my Midland is basically the same design and it works very well. |
Regarding this discussion,
"I got a price from White Post (who bought out Ed) for the Midland for $595. OR i can get a new PBR vh44 out of Australia for about $400 including shipping. The VH44 has a 3/4" bore. The generally available VH44 (chinese) from Ebay have a 5/16" bore.. Cheap at 64$. but could prove to be "undersized" I believe this is a mistake by the Chinese in description. I bet the 5/16" is referring to the "VALVE PISTON ASSEMBLY" and NOT the slave cylinder bore. -5/16" OD slave would NOT move enough fluid volume - The Chinese copied the AUS design! and they sure wouldn't come up with a change leading to a non-functioning booster." I found a table this morning confirming my comment. The slave cylinder is most likely 3/4" diameter but may be 5/8" |
Just a mention on the early 59's F100 brakes - you can install the 60's F100 self adjusting hardware with a few mods ti the grease shield. I have them on my avatar and they work pretty well.
#13 |
#14 |
Here you go Tim
#15 |
Glenn. Most of what I read suggest that I may need grind my 1940 spindles to fit the 56 assembly. do you know if this is a simple grind or will I be at it all day? other reads suggest that I use 46-48 spindles (Curt Baker), but I really don't want to tear up that much if the grind is mostly pretty straight forward,
#16 |
Just bought a pretty clean complete 1956 F100 set up without hubs for $175.
#17 |
Pictures of F-1/F-100 brakes with later self-adjusting hardware.
Parts needed: self-adjuster kit H2540 self-adjuster kit H2541 self-adjuster kit hardware H7144 Also need to notch the shoe retainer (or use a later retainer) to clear the forward spring. |
#18 | |
The spindle in pictures is ground on both sides for unknown reasons (symmetry?). Only one side actually needs to ground. The 144116 inner bearing used to fit F series hubs has a square inner corner; I usually use a die grinder to bevel that edge to match the radius on Ford spindles. Last edited by rich b; 03-09-2026 at 04:07 PM. |
#19 |
Rich... you caught me off guard with this data! in all my research and old school instructions, I have not come across this self adjusting hardware kit. Is that something that further improves the braking ability of the 1956 F100 brake set up. I note that the gear seems to apply to the late 60's. What can you tell me?
#20 | |
| Thread Tools | |
| Display Modes | |
