Old 03-04-2026, 04:12 PM   #1
jimTN
Default Re: 2 Bolt distributor initial timing aid
Just set it to where it starts best an runs best, simple as that. You do not need a fancy tool, only a screwdriver.
Old 03-04-2026, 04:45 PM   #2
Sid
Sid's Avatar
I know that. This is for after you install new points and do the initial timing set up. I have done it the old school way measuring from the bolt hole. This looks like it can make it just a little easier.
Sid is offline   Reply With Quote
