Old 02-27-2026, 05:21 PM   #1
CallmeBob
Default 3rd gear noise
I've got a 41 Mercury coupe, motor and trans was rebuilt a little over two years ago, drove several times with no problems. Today I went for a drive it shifted good through 1st and 2nd gears with no noise, but when I shifted into 3rd it instantly started making a noise like a whine with a light rattle mixed in. It don't matter how fast or slow I'm going, if I have clutch pushed or not the sound is still there. When I put it back in 1st or 2nd the sound goes away. Can anyone tell me what may cause this, and a easy way to fix it without pulling the trans.
CallmeBob is offline   Reply With Quote
Old 02-27-2026, 05:41 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: 3rd gear noise
I’m sure you know this but 3rd gear is direct drive. I don’t know what the issue is but feel for sure it will need to come out. Driving it may possibly damage it further. I’m sure you will get some crystal ball readers that will tell you what your problem is. Good luck.
Old 02-27-2026, 05:57 PM   #3
hueyhoolihan
if the pitch of the noise does not vary regardless of speed, then i would think it may not have anything to do with the transmission. but might have something to do with the shift linkage. ...possibly interfering with something in the torque tube or driveshaft depending on what you've got.
umm... your neighbors haven't mentioned anything about their cat missing have they?
hueyhoolihan is offline   Reply With Quote
Old 02-27-2026, 06:24 PM   #4
CallmeBob
No ones said anything about any cats missing. It is a torque tube. The noise does speed up and slow down with speed.
Old 02-27-2026, 06:26 PM   #5
CallmeBob
I need to sell it as soon as I get it fixed to help pay medical bills.
Old 02-27-2026, 06:28 PM   #6
hueyhoolihan
good to hear that the hypothetical cat was just that...hypothetical. and if the sound varies with speed my suspicions about something other than the transmission being the source of the noise are much less likely. i was hoping for the best, i guess. good luck.
Old 02-27-2026, 09:16 PM   #7
Ken/Alabama
Ken/Alabama's Avatar
This was my issue with the transmission in my 40.
Old 02-27-2026, 11:07 PM   #8
petehoovie
petehoovie's Avatar
Old 02-28-2026, 06:34 AM   #9
Mac VP
Mac VP's Avatar
A proper diagnosis would require a thorough tear down of the transmission. If I had to make a guess, I would also suspect the roller bearings. The last 15-20 years of these that have been available as new reproduction parts have proven to be defective. The assembly techniques and the heat treating are the culprits…….these repro roller bearings may last for a little bit but usually within 500 to 1000 miles they come apart, as shown in the photo above. I wish the offshore manufacturer would make the necessary improvements. However, as long as the various USA vendors continue to buy them there is no incentive to make any changes. As much as we would love to install some shiny new bearings, or sell them for customer parts orders, we refuse to do so.
I have strong opinions about some of the reproduction and aftermarket parts sold in the hobby, but this issue has always been the number one problem to me. I’ll step down from the soapbox now…..
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is online now   Reply With Quote
Old 02-28-2026, 10:29 AM   #10
Terry,OH
Terry,OH's Avatar
noise with the clutch pushed or not could be the throwout bearing riding on the pressure plate fingers.
Old 02-28-2026, 12:46 PM   #11
CallmeBob
The sound is only in 3rd gear, if it was the throw out bearing the sound would be in all gears, I assume. My hearing is not very good so I got my neighbor to listen. He said the whine is not very load, but the rattle sounds like when you run a powered drain snake down a drain and it's hitting on the sides of the pipe.
Old 02-28-2026, 01:49 PM   #12
GB SISSON
GB SISSON's Avatar
The last sentence coupled with the photo in post#8 makes a very good argument for sourcing NOS or NORS bearings, no matter how hard they are to find. And this applies to far more parts than just bearings.
Old 02-28-2026, 05:25 PM   #13
Kurt in NJ
Kurt in NJ's Avatar
have you checked the oil levels in the transmission and rear axle.
Rear axle problems become more evident with speed and may not make noise in lower gears.
Old 02-28-2026, 11:07 PM   #14
hueyhoolihan
i'm still hoping it has something to do with something outside of the gearbox. although the fact that it only happens in 3rd gear could be actually something that happens due to reaching a specific speed and not 3rd gear. meaning it could be in the torque tube, differential or even in an axle.
Old 03-01-2026, 01:35 AM   #15
ford38v8
ford38v8's Avatar
Good call. They walk among us.
Alan
Old 03-01-2026, 08:11 AM   #16
CallmeBob
It happens no mater what the speed. With the clutch push in it makes the sound all the way to a stop, so speed has nothing to do with it. I have not tried shifting into 3rd at a lower speed, maybe I should do that.
Old 03-01-2026, 09:20 AM   #17
pistonbroke
I'm with Mac. In third gear the lower luster is free floating, with no presure or load on it s it can rattle around and whine due to a slight misalignment until you load it it by shifting to first or second. Tim
Old 03-01-2026, 10:59 AM   #18
Bored&Stroked
Bored&Stroked's Avatar
My bet is that you had aftermarket cluster roller bearings . . . they are junk. I only use original Ford stuff (even used) - they don't fall apart like the repop ones.
Old 03-01-2026, 12:10 PM   #19
KiWinUS
KiWinUS's Avatar
Have you drained the oil to see what comes out?
Old 03-01-2026, 03:04 PM   #20
CallmeBob
I think I figured it out. I when for a short drive today after adjusting the linkage and still had the sound. Went past the neighbors house and he call and said he didn't hear the sound when I went by, but I could still hear it in the car. I also noticed my speedometer was jumping all around so I disconnected it at the transmission and the sound went away. So I'm thinking I have a bad speedometer cable. By the way I got the transmission kit from Dennis Carpenter.
