Old 02-08-2026, 01:13 PM   #1
hpk 53
Default ing coil
1940 ford buisness coupe instaled 2 coils both shorted out ,6 vols in no volts out
hpk 53 is offline   Reply With Quote
Old 02-08-2026, 01:17 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: ing coil
Are points open?
KiWinUS is online now   Reply With Quote
Old 02-08-2026, 01:42 PM   #3
hpk 53
yes rebult disturber
Old 02-08-2026, 02:37 PM   #4
Ken/Alabama
Ken/Alabama's Avatar
Does it have the resistor underneath the dash connected ?
Old 02-08-2026, 04:10 PM   #5
hpk 53
do not know where is it
Old 02-09-2026, 11:59 AM   #6
19Fordy
19Fordy's Avatar
hpk53:
Here's the resistor. Look at Post #2. It's on the driver side on firewall.
https://www.fordbarn.com/forum/showt...+dash+resistor
Old 02-09-2026, 12:40 PM   #7
petehoovie
petehoovie's Avatar
Originally Posted by 19Fordy View Post
hpk53:
Old 02-09-2026, 03:21 PM   #8
hueyhoolihan
coils should show continuity between the + and - studs (they could be marked with something like a "FLD" or "BAT" or some other mnemonics) but there will be no continuity at the high voltage (tension) outlet between either stud.
if hooked up to a battery such that one of the coil's studs is connected to one the of the battery's terminals and the other stud is connected to the other terminal, the coil will emit current (and a very, very high voltage current) from the center outlet to ground, only when one of the coil's studs is disconnected from the battery.
the voltage may be high enough to jump an air gap of up to an inch to get to ground.
hueyhoolihan is offline   Reply With Quote
Old 02-10-2026, 11:57 AM   #9
rotorwrench
rotorwrench's Avatar
The high tension secondary is connected to one side of the primary but it doesn't form a circuit in a normal sense. It just has access to the breaker that way. Some old ones are marked sw and dist to keep polarity correct.
Old 02-11-2026, 03:06 PM   #10
hpk 53
THANK YOU FOR THE HELP THIS , IS MORE INF 1940 FORD BUINESS COUP FLATHEAD 6 VOLT , DISTRIBUTIOR / COIL IN FRONT OF ENGINE , ENGINE IS 221 , Have new coil im afraid to install thanks
Old 02-11-2026, 03:45 PM   #11
35fordtn
35fordtn's Avatar
If you are using reproduction 1937-41 Ford coils that look original that is likely your issues. They are made by carpenter and are truly junk/
Old 02-11-2026, 07:08 PM   #12
hpk 53
i am using a reproduction with scrip from China bought in us [ drake ]
Old 02-11-2026, 08:12 PM   #13
35fordtn
35fordtn's Avatar
That coil and the only original appearing "NEW" coil is made by carpenter. We are a carpenter dealer and refuse to stock them due to the issues with them. Your best bet is to have a original rebuilt by Skip Haney, or use a adapter plate with a modern type .8 ohm round coil.
Old 02-12-2026, 02:31 PM   #14
hpk 53
how do i find skip haney
Old 02-14-2026, 01:36 PM   #15
corvette8n
corvette8n's Avatar
https://skipscoilsandpumps.com
Old 02-14-2026, 02:23 PM   #16
petehoovie
petehoovie's Avatar
Specializing in 1932 - 1948 Ford Flathead Coils, 1932 - 1953 Ford Flathead Water Pumps,
Also V-12 Lincoln and Mercury
George (Skip) Haney Coils and Pumps
941-505-9085
941-639-0920
[email protected]
Hours
Monday - Friday: 9am - 5pm
Old 02-14-2026, 02:35 PM   #17
hpk 53
thank all of you for the help
Old 02-15-2026, 03:47 PM   #18
hpk 53
how do you test ignition resistance , what dose it do
Old 02-15-2026, 05:09 PM   #19
hpk 53
thank all ,i found the problem
Old 02-15-2026, 07:38 PM   #20
tubman
tubman's Avatar
Well, what was it? We love solutions. Tie a bow on this thread.
