Old 02-11-2026, 06:46 PM   #1
3W Hank
Default Wittek clamps
Questions on Wittek clamps.
First. Are they numbered in sizes ?
For example I has 5/16” rubber in US made fuel lines betwwen the LZ carbs but plan to has 3/8” from tank under car to firewall.
I also has water tubes ( FH ) and I think OD on rubber might be round 2.3”.
Any suggested sizes ?
Then, how are the periods, can one see dates, if had the older holes or cadmid surface or steel.
I has bought some from 2 ( 3 ) places but will get them soon but now I bought 3/8” as he said work fine and dated 4/48. No holes but look like a steel shell.
Others I bought, seen pictures is cadmid surface some with holes, some not.
No detail on numbers ( size ) or date.
Will soon know.
I has only 2 of the larger ones ( 60 mm )
But I need 10 more.
Its not that easy try figure all this out and find the parts.
Some of my buddys say I’m a nut.
Shore, I can go to Walmart, but its not that fun.
3W Hank is offline   Reply With Quote
Old 02-11-2026, 07:04 PM   #2
Tim Ayers
Default Re: Wittek clamps
For fuel line, you need Wittek's #2. They are getting VERY hard to find. Nystrom is making new ones if you can't find old ones.
The ones I have seem to all be stainless steel, but with different coatings depending on when they were made.
I am a stickler for details and hose clamps are one of those things where I have no issue paying up to ensure they fit the era of my car.
I've buy #2's whenever I can find them.
Old 02-11-2026, 07:30 PM   #3
3W Hank
The ones I bought was just told be either fit 5/16 or 3/8, but if you say Nr 2 how wide is thoose in diameter ( lose ) ?
Do you has 5/16” rubber fuel lines to carbs ?
Old 02-11-2026, 08:15 PM   #4
Tim Ayers
I'll check tomorrow for you.
Old 02-12-2026, 09:13 AM   #5
alchemy
alchemy's Avatar
Nystrom repros? Any link?
alchemy is offline   Reply With Quote
Old 02-12-2026, 09:32 AM   #6
Tim Ayers
Here ya go:
https://nystromperformance.com/produ...uel-hose-clamp
Old 02-12-2026, 09:44 AM   #7
Tim Ayers
As mentioned, Wittek #2's the correct size for 5/16" fuel line. Any larger, they don't clamp the hose on the nipple correctly.
Here is the hose I've used.
Old 02-12-2026, 05:44 PM   #8
3W Hank
I has around 30 of the now and this was I bought today dated 4/48, just as I like ! ( Nr 2 )
Super happy.
Old 02-12-2026, 10:52 PM   #9
leon bee
^^^ Fuel hose from Turkey. I've only just started noticing Turkey in some parts here and there.
leon bee is offline   Reply With Quote
Old 02-12-2026, 11:50 PM   #10
tubman
tubman's Avatar
Wittek clamps are used a lot in early Corvettes. They have been re-popping them for at least 40 years. Any dates during that period are readily available. I would expect that's not an unusual case.
Old 02-13-2026, 01:41 AM   #11
itslow
itslow's Avatar
Corvettes don't use the thumb screw style clamps that the hot rodders want.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 02-13-2026, 03:53 AM   #12
tubman
tubman's Avatar
The thumbscrews are the easy part.
Old 02-13-2026, 06:52 AM   #13
Tim Ayers
Not sure on which size clamps are used on Vettes, but #2's are very hard to find.
Old 02-13-2026, 06:53 AM   #14
Tim Ayers
Right? Crazy. I recently installed some lower control arms for a Mazda that were made in Turkey.
Old 02-13-2026, 03:30 PM   #15
3W Hank
Here is my 3 orders, hard to think this is repro and I guess it’s 40’ most of them.
Some told me early ( 40’s ) is cadmidded but 50’s has steel band but the ones dated 4/48 has steel bands.
Old 02-13-2026, 05:20 PM   #16
Tim Ayers
That is a good haul, Hank. Like I said, #2's are getting very difficult to source. I'm curious about Nystrom's clamps.
Mine are mix of stainless and cad plated. Could be for different applications. I'd assume stainless was aviation, but I have no way to verify.
Old 02-13-2026, 06:58 PM   #17
3W Hank
Tim, when I has all of them here I will show all details of them.
This is fun.
Old 02-13-2026, 08:43 PM   #18
busmania
busmania's Avatar
I bought some of the nystrom clamps when they first came out (just a few months ago if I recall correctly). I haven’t installed them yet. Let me know if anyone wants detailed pictures of them. They are not installed yet as my car is at the interior shop.
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/
busmania is offline   Reply With Quote
Old 02-14-2026, 10:14 AM   #19
3W Hank
It always good when good repros comes out, please show them.
I think the old Nr 2 is not that hard to find, but the bigger ones to water tubes is really hard. I has only 2 of them, but I has 12 NOS std Ford.
Old 02-14-2026, 02:09 PM   #20
3W Hank
On Wittek clamps to FH water tubes, I has the std Ford clamps and they are
marked A - 2.1/8 ( 2.125" )
Open ( end of screw ) they are around 2.20".
One friend showed me his Wittek clamps, marked #36 and showed the rubber
hose is 54 mm or as the std Ford 2.1/8".
The ones I bought, I has not them here yet is 60 mm or 2.36".
-But seller told me that is what he used.
The bigger ones is hard to get, so now I has just 2 of them.
Ideas of this ?
