Old 01-31-2026, 06:39 PM   #7
hueyhoolihan
Default Re: 1937 Ford rear axle ratio
Originally Posted by glennpm View Post
This will give you a pretty good ball park of the ratio, which can be compared with known ratios (4.11, 3.78, 3.54) to see which one comes closest. For example, put a mark on the brake drum, straight up or down is convenient, then rotate the pinion 2 turns. If the brake drum mark indicates slightly less than one turn for the two pinion rotations, it indicates lower, higher number ratios such as 4.11 or 4.54.
DETAILS:
- Make a chalk mark on the bottom or top of the tire or brake drum
- Rotate the engine or pinion shaft exactly 2 revolutions.
- Measure the rotation on the tire or brake drum. It will be plus or minus one turn. Accuracy with these measurements is critical.
- Take this tire or drum rotation value, divide it into 1 (in other words, find its reciprocal),
- Then multiply it by 4.
EXAMPLE:
4(1/X) = 3.54
X = 1.12 (Drum or tire rotation value)
CLOCK BIG HAND INDICATION:
.12 x 12 = 1.44 or about 10:30
A) Between 1 and 2 o'clock, ratio is 4.44
B) Between 12 and 1 o'clock, ratio is 4.11
C) Between 11 and 12 o'clock, ratio is 3.78
D) Between 10 and 11 o'clock, ratio is 3.54
excellent advice! better cannot be had!
hueyhoolihan is online now   Reply With Quote
