Old 01-22-2026, 10:10 PM   #1
GUERRINIRACING
Default Crank shaft
Does anybody recognize ths crank shaft 59 block with threaded oil gallery plugs next to each rod journal---???? The casting is diff to have these---as of now its a mystery-----
GUERRINIRACING is offline   Reply With Quote
Old 01-22-2026, 10:12 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Crank shaft
Attachment 580633
Old 01-23-2026, 07:09 AM   #3
KiWinUS
KiWinUS's Avatar
Yes I also have one. You may not get as many answers on here as you did on Facebook.
Old 01-23-2026, 07:41 AM   #4
Tim Ayers
Tony,
Any insight as to where it came from or its backstory?
Old 01-23-2026, 08:28 AM   #5
KiWinUS
KiWinUS's Avatar
Originally Posted by Tim Ayers View Post
Tony,
Yes Tim , it’s from the first flathead I ever bought when I was 15 still have it. Would be a Canadian engine. 41 Merc. Has the 4 freeze plugs in panels like earlier engines. Is 3 3/16” bore.
Old 01-23-2026, 10:21 AM   #6
Bored&Stroked
Bored&Stroked's Avatar
Now THAT is a weird one! I've never seen that flathead crankshaft and God knows I've looked at a 'few' in my 50+ years of working on these goofy engines! Thanks for the pics and thanks Tony for the information.
Old 01-23-2026, 11:01 AM   #7
GUERRINIRACING
Then can you tell me were-its from??????-how about a picture--this was built 45 years ago---
Old 01-23-2026, 11:03 AM   #8
GUERRINIRACING
And it has a rope rear main seal to------with floater rod bearings---pre 49-------------?
Old 01-23-2026, 11:05 AM   #9
GUERRINIRACING
Ok tim were did yore motor come from??? This is a 46 or latter---59 series block--?????in a 40 coup --ca car--
Old 01-23-2026, 03:00 PM   #10
glennpm
glennpm's Avatar
"After WW2 Canada produced their own variation of the 59 series motors, the C69A. These had special insert rod bearings that ran in crankshafts with two oil holes per rod throw (like the later 8BA cranks) and used modified floating type rods with tangs added to locate the thick bearings. Functionally the C69A blocks are equivalent to USA 59 blocks, unless you happen to get a full flow modified block.
The C69A casting on the top of the bell housing and extra oil port are shown in this picture."
I don't see threaded crank plugs in this picture.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 01-23-2026, 03:17 PM   #11
Newc
Newc's Avatar
Possible WW2 Military production. Extra port for oil cooler. Many were surplus after War -have one in my 114X Mercury. Canadian Ford war production started 1938. Newc
Old 01-23-2026, 04:50 PM   #12
GUERRINIRACING
Thanks--so it would have the diff crank?????not sure how that crank got into my motor-------45 years ago it was built---?????
Old 01-24-2026, 07:01 AM   #13
glennpm
glennpm's Avatar
Nothing wrong with what you have. What are the raised letters on the upper portion of the bell housing?
Rumble Seat’s Notes
Old 01-24-2026, 03:08 PM   #14
KiWinUS
KiWinUS's Avatar
Here’s my crank and block it came in. I have owed this engine for 55 years the first flathead I bought and still have it. Block is about to get a stroker crank and all the goodies.
Old 01-24-2026, 03:45 PM   #15
petehoovie
petehoovie's Avatar
Old 01-24-2026, 08:10 PM   #16
Bored&Stroked
Nothing like a good ole' 'Keystone' block - looks very similar to a 1940 Merc block (which weren't relieved), or a WWII military/industrial block (with the factory relief).
Old 01-24-2026, 08:21 PM   #17
tubman
tubman's Avatar
Completely off-topic, but was that block de-rusted by soaking in a molasses solution? I saw one years ago that had the same surface condition because it had been derusted with molasses.
Old 01-25-2026, 07:31 AM   #18
KiWinUS
KiWinUS's Avatar
It has been shake and bake cleaned. Has never been rusty.
Old 01-25-2026, 10:15 AM   #19
mfirth
I remember seeing a block with "that patina" years ago and wondering why it looked like that. Interesting stuff about this crank for sure, thanks everyone & Denny.
mfirth is offline   Reply With Quote
Old 01-25-2026, 12:19 PM   #20
Tim Ayers
Interesting, Dale. I have three "keystone" blocks. Two are not relieved and one is. Sadly, the relived and one of the non-relieved are cracked in the #3 intake. Not sure what I'm going to do with them. They are all raised intake and 3 3/16" bore, so like you said, similar to Merc blocks.
