Old 01-16-2026, 09:02 PM   #1
Kube
Super Moderator
Kube's Avatar
Default Prefix id help please
Guys, I have a bunch of parts I am attempting to identify.
Can't seem to locate the prefix ID.
Any help much appreciated.
AE
8M
8CM
1M
FEW
COAF
C5TZ
Thank you.
Old 01-16-2026, 09:55 PM   #2
mcgarrett
Default Re: Prefix id help please
8CM generally indicates a Mercury engine part from '49-'53
C5TZ is a later chassis/drivetrain number from the mid sixties.
Sorry, not too sure about the others.
Old 01-17-2026, 12:04 AM   #3
nelsb01
nelsb01's Avatar
8M is 1949-50 Mercury and also 1949-50 Ford Station Wagon (although mostly drivetrain and chassis parts)
1M is 1951 Mercury
nelsb01 is offline   Reply With Quote
Old 01-17-2026, 08:28 AM   #4
Kube
Super Moderator
Kube's Avatar
Thanks guys. Already a huge help!!!
Old 01-17-2026, 08:43 AM   #5
glennpm
glennpm's Avatar
Not exactly answering your query, but the attached "Early Ford Serial Numbers - The Flat-Spot" from Nate Cooper I find helpful.
Glenn
File Type: pdf Early Ford Serial Numbers - The Flat-Spot.pdf (128.8 KB, 13 views)
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 01-17-2026, 08:44 AM   #6
fordyford
fordyford's Avatar
COAF is 1960 full size car C5TZ is 1965 truck 8M is 1949 Mercury 1M is 1951 Mercury
FEW may be late "50s" Merc?
fordyford is offline   Reply With Quote
Old 01-17-2026, 08:50 AM   #7
Kube
Super Moderator
Kube's Avatar
Wow! Thanks again!
Old 01-17-2026, 09:47 AM   #8
1942deluxe
1942deluxe's Avatar
FEW is 1958 Mercury.
Old 01-17-2026, 10:24 AM   #9
Kube
Super Moderator
Kube's Avatar
Thanks so much!
Old 01-17-2026, 12:57 PM   #10
Karl Wescott
Karl Wescott's Avatar
By the 1960's Ford had settled down to a consistent prefix system. LETTER+NUMERAL+LETTER+LETTER.
The first letter denoted the decade, C=1960-1969, D=1970-1979, E=1980-1989 etc.
The numeral denotes the last digit of the year, C0xx=1960, D1xx=1971, E9=1989 etc.
The next two indicate model and chassis. I have no clue what the mean and less inclination to learn.
Note they have kept the chassis parts body numbers mostly intact, so a C0AF-8100 could hypothetically be the radiator cap for the 1960 car.
Karl
Karl Wescott is offline   Reply With Quote
Old 01-17-2026, 01:57 PM   #11
1942deluxe
1942deluxe's Avatar
I spent over 30 years in Ford dealerships. I did everything from being the wash boy to being the dealer. As Karl mentioned there was a P/N prefix, base number, and suffix. The 60's,70's,80's numbers were fairly easy to recognize just by looking at the number on the box. The third digit(letter) of the prefix told you what model. A was full size, D was Falcon, Maverick and later became Taurus, O was Fairlane (Torino), S T-Bird, T truck, U Econoline. As Karl said many of the base numbers never changed. 11654 as an example is a light switch. The suffix does matter. At one of the first dealerships I worked at they told the new parts guy to order 6 sets of pickup fenders. We ended up with 6 sets of the original size Bronco fenders. I'm sure they'd bring a fortune today as NOS. Sometime in the 90's they went to "Global" prefix's which I never really grasped.
Old 01-19-2026, 08:04 PM   #12
1942deluxe
1942deluxe's Avatar
Mike,
The B8A-18512-E (C) neutral safety switch you have listed is for a 58 Ford with Cruise o Matic if anybody asks. Number changed to B8AZ-7A247-B later on. I have the chassis parts books 1928-64 if you need any other part numbers researched. Actually, still enjoy doing that!
Old 01-19-2026, 08:06 PM   #13
Kube
Super Moderator
Kube's Avatar
Mike,
Thank you, thank you, thank YOU!
Old 01-19-2026, 09:22 PM   #14
1942deluxe
1942deluxe's Avatar
Also, your FEW-15843-B (58 Mercury) is a transmission control inhibitor switch. " On rear of keyboard selector, 383 (mod.) 383-430 engines".
