Old 01-16-2026, 09:45 AM   #1
Henry Ford IV
Default 1935 Thermostats
Looks like I need thermostats, none provided in the parts that I have, to put the car together. I am not concerned with originality here, you won't see them. Must I get the original style that a vender sells for $110 per pair or can I get modern looking ones from one of the venders for $7.99 each?
Henry Ford IV is offline   Reply With Quote
Old 01-16-2026, 10:52 AM   #2
rockfla
rockfla's Avatar
Default Re: 1935 Thermostats
Originals (or original types) are always your best bet, they fit as designed for a reason, depending on the "modern" type you get, they "Can" get sucked up into the outlet hose and displaced from the required position.....SO that is always a possibility with certain modern stat's. You can also find original (OR NORS) on Ebay "fairly" easily as well.....BUT where it me, I'd look for the "original" type IF at all possible. JMO
Old 01-16-2026, 12:23 PM   #3
37 truck
There are some of us who wire the modern thermostats in place. I like to put a piece of stainless-steel pipe into the hose to hold the thermostat against the head. It can be secured with an additional hose clamp.
37 truck is offline   Reply With Quote
Old 01-16-2026, 12:28 PM   #4
deuce lover
deuce lover's Avatar
32 -36 is not the same application as the 37-48. The 32-36 uses a thermostat that is in the
upper hose and an additional hose clamp is needed to secure it in place.
Old 01-16-2026, 01:06 PM   #5
Henry Ford IV
I checked eBay and found two NOS with proper tangs for $22 each. Original and a good deal.
Old 01-16-2026, 01:43 PM   #6
34fordy
34fordy's Avatar
When I have used NOS thermostats, I always use a thermometer and warm them up in a pan of hot water to make sure that they open properly before installation.
34fordy is online now   Reply With Quote
Old 01-16-2026, 01:45 PM   #7
Kube
Super Moderator
Kube's Avatar
Be certain to place them in a pan atop your stove with a kitchen thermometer in the water. Bring the water up to temp and watch carefully that the thermostats open at approximately the correct temperature.
Do not believe that "new", "NOS", equal "good".
Kube is online now   Reply With Quote
Old 01-16-2026, 07:23 PM   #8
Henry Ford IV
Got it. Will do. My wife gave me 3 old pots "for the car" last week, so they will be put to use.
Old 01-17-2026, 06:59 AM   #9
Bob56
Bob56's Avatar
Watch the ones on ebay as most of them have been 155°
Bob56 is offline   Reply With Quote
