Old 01-12-2026, 08:09 PM   #1
411Ton
Default Bed Chain Bracket needed
Does anyone have a bracket like this picture? All repro's I find are quite different. Functional, but can't even be called similar... This is a 8' bed, but I'm not sure that makes any difference. Thanks! Pls PM me if you can help!
411Ton is offline   Reply With Quote
Old 01-12-2026, 09:34 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Bed Chain Bracket needed
Old 01-12-2026, 11:40 PM   #3
OldGold360
Worst case, you can repair it or have a qualified shop repair it. I’ve repaired a lot of items like this, steel and aluminum, and have even matched textures. I’m not sure if reproductions are available just like this one, but wanted to make you aware that repairing it is possible if you can’t find one.
OldGold360 is offline   Reply With Quote
Old 01-13-2026, 04:02 AM   #4
Mart
Mart's Avatar
I'd say it being an 8' bed does make a difference. My 1/2 ton 41 has a folded pressed steel bracket and the rivets are oriented differently. So unless you can find some good ones a careful repair might be appropriate. If it is a forged piece you ought be able to weld it. If cast then more specialised repair might need to be used. (brazing etc). Looking at it, it might be ok to just clean up what has already been done and improve the cosmetics of the piece.
Old 01-13-2026, 09:51 AM   #5
GB SISSON
GB SISSON's Avatar
After the sun comes up I will go look and see what is on a rusted out 8' bed from a '48-'52 F3.
Old 01-13-2026, 12:22 PM   #6
petehoovie
petehoovie's Avatar
Old 01-13-2026, 06:15 PM   #7
kirkf
kirkf's Avatar
This is a picture of a 1941, 1 ton bed bracket.
It is different from the 1/2 tons.
I have not seen this part reproduced anywhere.
I would recommend repairing what you have, or ask in the wanted section.
Kirk
1953 Ford F100
1950 Ford F47 (F1)
1940 Ford Pickup
kirkf is offline   Reply With Quote
Old 01-13-2026, 06:47 PM   #8
petehoovie
petehoovie's Avatar
Kirk
Old 01-15-2026, 09:34 AM   #9
411Ton
thanks everyone for the comments. If no luck finding an original, will go with professional welder to repair. Should be able to resurrect it.
Old 01-15-2026, 09:27 PM   #10
GB SISSON
GB SISSON's Avatar
I keep forgetting to go and get a picture of it. I will PM you about it.
