#21 |
Is your EverStart battery charger a smart charger ? mean does it protect against reverse charging ?! It is easy to get things crossed up with normal positive ground , this could have damaged the alternator
#22 | |
Darn -- I caused it |
#23 |
#24 | |
As other's have said there may be a problem w/the car's wiring.
#25 |
According to the Everstart web site, I caused the problem when I miss-connected the charger.
TKS for everyone's input, going back to my spare Generator |
#26 |
#27 |
My alternator began giving me issues with the original size belt. I couldn't get it tight enough so it would only charge under light load (i.e., the belt would start slipping under higher resistance). I ordered a smaller belt and will see if that fixes it.
Feb '31 Standard Coupe Member of the Little Rhody Model A Club & MARC |
#28 |
Mile1291
Actually it's a new belt when it 'failed'. Anyway It waited until I send a spare off for rebuilding before it began to charge again. I'll keep checking. Thanks |
#29 |
Sounds like it may be an intermittent connection somewhere.
#30 |
Well, your not going to believe me, so here goes: When I stand Passengers door, alternator shows a charge. Drivers door, no charging. I checked this 6 times.
I have a 2024 PaceMaker if that's a clue. I've a video to prove my post, just don't have the skill needed |
#31 | |
When I got my pacemaker/defibrillator years ago, they told me refrain from getting too close to magnetic fields or running engines. At first I was afraid to start my Model A! Seriously!! But all was good when I got brave. I did stop electric welding tho on the advice of my electrician (Electrophysiologist) and plumber (Cardiologist). |
#32 |
I added the info about the pacemaker, just in case. And I'm keeping my video as proof when our club meets. Alls I know is that the Ammeter shows either a charge or neither, depending on the doorway I'm at. I'm along so I don't know where I'm at when it does it's thing. I can/t very well removed my PM
#33 |
I'm not supposed to weld with my pacemaker and don't, but the manufacturer's rep that downloads data from it twice a year says that she has welder patients who have continued their livelihood with no apparent bad effects. She didn't advocate it by any means.
#34 |
Since I'm not touching my truck to view the ammeter, I don't know what to think -- right now, it's my presents in the door way -- but I enter it to video (for my proof).
Now I do have 4 stents, and two new hips, just last year. What I need is a close club member to drop by, but that's not going to happen. I really need someone else to see this |
#35 | |
#36 |
#37 |
Does this phenomenon occur when someone else stands in the passenger door? Or just you?
#38 | |
I'm hoping a club member will help, we meet tomorrow, but that's 50 miles North. There's not a whole lot of Model A interests right near |
| Thread Tools | |
| Display Modes | |
