Old 01-09-2026, 09:39 AM   #11
Ziggster
Default Re: Holley 94 Rebuild - Secondary Carb
Sanded down the mating surfacing of the main body using 180 grit on a glass top. Got the top surface pretty good, but didn’t want to go too far on the bottom surface even though it was worse. Tough sanding the bottom surface with that “bump” in the way. Might try some of the copper gasket spray on those gaskets.
Ziggster is offline   Reply With Quote
