#21 | |
#22 |
The Edmund intake.
#23 |
#24 |
I mapped out the runners of the Edmunds intake. It was a month or two ago, and IIRC, it was an “open” intake, but your comment caught my attention. Geeze! Here’s a coloured coded diagram of the runners from each carb throat/opening. Let me know what you think. I’m on the road so can’t do much checking.
#25 | |
#26 |
https://www.xs650.com/threads/the-my...numbers.43752/ Last edited by Ziggster; 01-08-2026 at 07:25 PM. |
#27 |
With the new plates installed in the base and comparing that with the untouched stk base with stk throttle plates, when closed, the angle of the plates are very different between the new and old plates. The base with the new plates has a steeper angle when closed compared to the stk setup (distance between arrows). Not sure why that is, and not sure if that is good, bad or ugly. Was hoping with all the new parts it was just going to be a simple “rebuild”. Haha!
#28 |
Speedway does, or did sell throttle plates for secondary carbs. They have a different bevel than stock.
A trick to sealing the plates is to get some GM DAG 213 sealant for throttle plates. Paint it around closed throttle plates, wait for it to set, then pop open plates. My understanding is this was done at the factory on the tripower setups.
I dig coal, which provides motivation for EVs. |
#29 | |
#30 |
Your carb body looks really nice. Are the pics before or after the clear?
#31 |
Would you share contact information for vintage speed?
#32 |
Be careful of what you ask for.
#33 |
#34 |
#35 |
Went back and checked their catalogue info on those throttle plates, and indeed the bevel angle on the edge is 12 degrees vs the 5 degrees for the stk ones. So, that at least would explain the difference in the angles when closed. Will try to speak with Charlie today or on Monday.
#36 | |
https://www.jalopyjournal.com/forum/...1343799/page-2 |
#37 |
After much fiddling, decided for now, to go with these two stk plates that I gave a quick cleaning with some sponge sanding blocks. Not sure of the grit of each, but guessing maybe 180 and 220.
It’s not as good as the remaining stk base in terms of sealing, but when trying to blow through each throat, there is a lot of resistance compared to the new aluminum 12 degree plates. The bottom plate in the pic seals a bit better than the top plate. I have some Permatex bearing sleeve retaining liquid, and wonder if a coat of that might help. Will look into that separately. Now to continue with the rebuild. |
#38 |
Will have to come up with a washer of some sort for the end of the shaft. Not got to remove a stk linage from a stk shaft as there is no need for that linkage.
#39 |
Pic of base with plates installed showing length of new extended shaft. Not sure if I’ll need that much.
#40 |
Went to install the new hex head idle mixture screws with the new springs. Both were hard to install. One in particular was really bad. Checked and then noticed there were practically no threads left in that one bore. Re-tapped both, and new screws installed easily.
| Thread Tools | |
| Display Modes | |
