Old 12-15-2025, 06:07 PM   #28
Dec211975
Default Re: What type of alternator is this on my 40 Ford.
What voltage output do you get if you push a small screwdriver in the D shaped hole as shown in the # four picture (11 o'clock position). By using the small screwdriver to ground the regulator tab you bypass the regulator and are checking the max output of the alternator.
Dec211975 is offline   Reply With Quote
