Old 12-01-2025, 06:51 AM   #21
nkaminar
nkaminar's Avatar
Default Re: Quick Point Gap Setter
The shipping cost is not the cost of the stamps that is expensive but the labor to put it in the envelope. It also adds to the bottom line. I try to wait until I have a bunch of things to order so that shipping cost can be combined.
Old 12-01-2025, 12:27 PM   #22
Ted Duke
Has shipping become a moneymaker?
https://www.excelerateamerica.com/ve...ping-discounts
Ted Duke is offline   Reply With Quote
Old 12-01-2025, 12:48 PM   #23
joncrane
Model A 1929
I was always told DO NOT TURN MOTOR OVER WITH THE FAN. That is one of the most likely causes of Fan cracking and blade failure. Crank it or use a wrench on the crank nut.
I am always tempted to try and nudge it one way or the other with the fan blade, but have resisted...Have not lost a fan blade yet.
joncrane is offline   Reply With Quote
Old 12-01-2025, 01:13 PM   #24
alexiskai
alexiskai's Avatar
I don’t know that I would try to use the fan to turn a motor against compression, but if the plugs are out you absolutely can use the fan. Won’t hurt it a bit.
Old 12-01-2025, 11:30 PM   #25
ModelA29
ModelA29's Avatar
Originally Posted by joncrane View Post
Model A 1929
Neither have I. I doubt I'd try it with an original fan or a plastic one but the new aluminum ones no problem. You'll probably need to push on the belt at the same time to get it tight enough to have enough traction to turn the engine.
ModelA29 is offline   Reply With Quote
Old 12-02-2025, 06:48 AM   #26
AKJurnee
Takes two minutes to remove the sparkplugs, might as well check the plug gaps while your feeler gage tool set is out at that point.
With the plugs out the engine is so easy to turn even if you use the fan belt to turn it.
BTW , you can legally mail a potato through the USPS by writing a mailing to and return address with a sharpie and a few stamps. It’s recommended you take it in the post office for actual weight though.
AKJurnee is offline   Reply With Quote
Old 12-02-2025, 12:50 PM   #27
Ray in La Mesa
I've seen bananas mailed that way, the first postal employee in line smiles & the last one goes "UGH".
Ray in La Mesa is offline   Reply With Quote
Old 12-02-2025, 02:08 PM   #28
Bruce of MN
Bruce of MN's Avatar
Our post office has an addressed flip-flop on display.
Old 12-05-2025, 08:28 PM   #29
katy
katy's Avatar
Why aren't they delivering it?
Old 12-05-2025, 08:48 PM   #30
Bruce of MN
I assume it was donated, I'll ask next time.
Old 12-06-2025, 12:51 AM   #31
Mel Larsen
After reading this post about the "quick point gap setter" I went out to my shop and machined one with my lathe, then milled the needed feeler gage, and it works ok.
Mel Larsen is offline   Reply With Quote
Old 12-06-2025, 01:34 AM   #32
Y-Blockhead
Y-Blockhead's Avatar
Fantastic! I love to hear when people make their own tools.
Old 12-06-2025, 10:28 AM   #33
katy
katy's Avatar
Here ya go: https://www.homemadetools.net/forum/
Old 12-06-2025, 10:59 AM   #34
Y-Blockhead
Thanks Katy. That should keep me out of trouble for awhile...
Old 12-06-2025, 11:37 AM   #35
nkaminar
nkaminar's Avatar
Machine shop time is now about @80 per hour. So if you like making tools in your machine shop then go for it. Otherwise it is usually less expensive to buy them.
