Old 08-11-2025, 04:24 PM   #1
Steve OK
Default Intake manifold on 59a-b
Oops dropped a nut down the intake port. Can not feel it around the openings so I guess I will have to pull intake manifold. Question do you need to drain coolant to be able to pull manifold. Got a ford 59 a-b
Thanks guys
Steve OK is offline   Reply With Quote
Old 08-11-2025, 04:28 PM   #2
Kens 36
Kens 36's Avatar
Default Re: Intake manifold on 59a-b
Steve,
No, you should not have to. Have you fished around with a magnet?
Ken
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 08-11-2025, 04:52 PM   #3
Steve OK
Did try briefly with one, but going to try more before I end up pulling.
Old 08-11-2025, 05:35 PM   #4
hueyhoolihan
hopefully, you won't let it happen two or three more times before learning to be careful...like somebody i know.
hueyhoolihan is offline   Reply With Quote
Old 08-11-2025, 06:26 PM   #5
big deuce
big deuce's Avatar
Try a shop vac too
big deuce is offline   Reply With Quote
Old 08-13-2025, 11:50 AM   #6
itslow
itslow's Avatar
No coolant runs through the manifolds of a Flathead V8.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 08-15-2025, 12:17 PM   #7
slowforty
I droped one in my 40 manifold. Went all the way down to cylinder 1. too bad it was stainless,
Go on Amazon, you can get a decent Boroscope for under $10. Some have magnets on the end,
slowforty is offline   Reply With Quote
Old 08-15-2025, 12:23 PM   #8
slowforty
I dropped one in my 40. Too Bad it was stainless steel.
Also go on Amazon. You can get a decent Boroscope, some have magnets on the endThat works with your Smart phone for under $10.
