Regarding downshifting: I forget whether your car has a Mitchell overdrive. If it does you can put the overdrive in neutral and then put the transmission in whatever gear you want without double clutching. Then put the overdrive back in gear. The overdrive has synchromesh so it will go in gear easily. Just make sure that the gear you chose is appropriate for the road speed you are going.
#2 | |
Thanks man. I'm really enjoying it. Put 101 miles on it yesterday going to lunch with some car club members; about 50 miles each way.
atch (Mike Atchley) Columbia, Missouri <>< |
| Thread Tools | |
| Display Modes | |
