Old 07-30-2025, 10:39 PM   #1
3949tl
Default 40 oil pan install
Am getting ready to install my oil pan, engine out of car on cherry picker, and am not certain the front “Rope” seal that came with the gasket set will work or that it is the correct one. As I see it, it seems too thick and after inserting it in the groove it rides too high and will not compress enough to allow the pan to sit flush with the side rails. Is there a different seal available that might be better? The seal looks to be a Teflon version as far as I can tell. No instructions with the gasket set. Am trying to do a “ dry” run before getting in to it. Thanks.
BTW. This is a stock engine.
3949tl is offline   Reply With Quote
Old 07-30-2025, 10:54 PM   #2
Newc
Newc's Avatar
Default Re: 40 oil pan install
always soaked those ropes overnite in engine oil. Common to use a sealer under them, but there is a drain-back hole under the seal. Also left the ends a bit long. Newc
Old 07-31-2025, 05:56 AM   #3
KiWinUS
KiWinUS's Avatar
What brand of gasket set? I use the rope type seals in my builds and I fit up totally dry then a smear of assembly lube on final assembly. I fit up timing cover with pulley on first then remove timing cover and do same with oil pan. Trim to length with a little excess sticking up now final assembly of timing cover,pulley,and oil pan. That’s how I have done this for many years.
KiWinUS is online now   Reply With Quote
Old 07-31-2025, 06:59 AM   #4
Terry,OH
Terry,OH's Avatar
Push the rope into the pan with a round rod about 1" Dia like a rolling pin.
Old 07-31-2025, 02:48 PM   #5
mcgarrett
As TerryOh says, push it down firmly into the seal groove and don't feel the need to trim too much off the ends. You want it to fit snuggly against the block without allowing leaks. If you have the correct gasket set for your engine you may not think it's possible, but it will compress as you begin to run all the pan bolts down. It is recommended to run the bolts down evenly so as not to put too much strain on any one area of the pan. As Newc says, it is very important to soak them in motor oil overnight before installing.
Old 07-31-2025, 04:19 PM   #6
KiWinUS
KiWinUS's Avatar
Why is it so important to soak them in oil overnight? I have built dozens of them and use the rope seals front and rear. I install seals dry then smear some assembly lube on them and crank on assembly as stated in post above with no leaks so after all these years what am I doing wrong?
Old 07-31-2025, 07:44 PM   #7
mcgarrett
All of the engine rebuilder books and articles I've ever read say to soak them in oil before installing. Every gasket kit I've seen has an instruction sheet that says the same thing. I've found the same instructions in Model A and Early V8 gasket sets. Just following trusted recommendations from people smarter than me!
Old 07-31-2025, 10:48 PM   #8
KiWinUS
KiWinUS's Avatar
55+ years of doing it wrong with zero issues and I figured my system out myself so try to educate what works from experience not what Joe blow ways or some no engine building engineer wrote on a piece of paper. I’ve built hundreds of engines from flatheads to race engines at the highest levels in the world. I’ll stick with what I know works. Best gaskets must be ripping me off not putting that note in the gasket sets I buy from them but that’s okay I believe I’ve got this. 😁
Old 07-31-2025, 10:49 PM   #9
KiWinUS
KiWinUS's Avatar
55+ years of doing it wrong with zero issues and I figured my system out myself so try to educate what works from experience not what Joe blow says or some no engine building engineer wrote on a piece of paper. I’ve built hundreds of engines from flatheads to race engines at the highest levels in the world. I’ll stick with what I know works. Best gaskets must be ripping me off not putting that note in the gasket sets I buy from them but that’s okay I believe I’ve got this. 😁
Old 08-01-2025, 10:40 AM   #10
3949tl
I’ve seen it explained both ways and am thinking either will work. My original concern about the seal being too thick still stands. I have pushed it in as far as it will go and have about a quarter inch sticking out on each end. After trimming it almost flush, I’m going to dry fit it and see if it compresses enough. Right now I have my doubts.
One more question: everyone suggests to “glue” the gasket to the block prior to install. What’s wrong with “gluing” it to the pan instead? It seems easier. I will put a dab of sealer on each corner of the end seals first.
Old 08-01-2025, 11:15 AM   #11
KiWinUS
KiWinUS's Avatar
I suggest you install as stated in my first post before trimming. That way you will know the seal is pressed all way in its groove. Then trim otherwise once pressed all way in it may be too short.
Old 08-01-2025, 01:49 PM   #12
3twinridges
3twinridges's Avatar
I wouldn’t soak them either. If you soak them in oil, they will be almost impossible to cut or cut cleanly. Assembly lube has worked for me also.
JB
3twinridges is offline   Reply With Quote
Old 08-01-2025, 06:02 PM   #13
3949tl
Thanks everyone. I did get around to doing a "dry" run and it looks like the front seal will compress enough and allow the pan to sit correctly. Being that I'm working from under the engine, actually laying along each side, while it"s hanging from the cherry picker, I am going to set the gaskets on the pan first and then lift it into place. ALL this for a clutch replacement!!!!
