Old 07-22-2025, 08:23 PM   #1
19Fordy
19Fordy's Avatar
Default How to test a solenoid
I have several 6V solenoids I would like to test to see if they work.
I want to test them on the workbench as I don't have a 6V car.
I do have a 6V dry cell battery and a 6V/ 12V BATTERY CHARGER.
Also have a digital volt/ohm meter.
Can I use the above equipment and wire them up to see if they are good solenoids? If so, how do I wire them? The solenoids I have are originally 6V with one post and the big BATT and Starter CABLE TERMINALS. The little button on the bottom appears to be for decoration as it cannot be depressed to work. I recall my OEM 1940 Ford solenoid had the bottom button that allowed it to be used to start the car when working under the hood. This solenoid does not have that feature.
Thanks, JIM
Old 07-22-2025, 08:38 PM   #2
petehoovie
petehoovie's Avatar
Default Re: How to test a solenoid
Thanks, JIM
Old 07-22-2025, 08:56 PM   #3
19Fordy
19Fordy's Avatar
Thanks Pete. Sure makes a difference.
Old 07-23-2025, 06:31 AM   #4
glennpm
glennpm's Avatar
Would a 6v output 110v input transformer like this one work? You would need one that could handle the solenoid amperage. Note I'm a Mech Engineer and not electrical so Koates, Tubman or a "sparks and arcs guy" could give us some guidance.
"6v output 110v input transformer"
https://www.amazon.com/UPMMUD-Transf...zcF9hdGY&psc=1
Sorry about that
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 07-23-2025, 08:51 AM   #5
tubman
tubman's Avatar
That link doesn't work for me.
Old 07-23-2025, 09:03 AM   #6
Terry,OH
Terry,OH's Avatar
Put your ohmmeter across the Bat and the small terminal and you need to see some minimal resistance (NOT zero ohms or infinite ohms) if so connect the + or - of your dry cell to the Bat and the other polarity to the small terminal. With your voltmeter connected to the second large terminal and the small terminal you should read battery voltage when the solenoid picks up. Digital voltmeter, ohmeter is good.
