Old 07-19-2025, 11:39 AM   #21
benbuilder
Default Re: juice brakes drag when rotating - only one way
I have ordered the "Green Book" because it seems like it has a lot of information. It has not arrived yet
In terms of correct set up of the braking system, do the two pictures look correct in terms of placement?
I cant really tell from picture in #9.
Thanks again
benbuilder is offline   Reply With Quote
Old 07-19-2025, 11:42 AM   #22
petehoovie
petehoovie's Avatar
Thanks again
Old 07-19-2025, 12:18 PM   #23
glennpm
glennpm's Avatar
No they're not correct.
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 07-19-2025, 12:26 PM   #24
cas3
That little clip is to make it so the spring can not go up inside the tube, However! as pointed out earlier in this thread, the new springs are sometimes too long and bunch up not allowing full travel when the brake is applied. In that case, let the excess spring go up into the tube, and stick the clip into the spring at the end of the tube.
Old 07-19-2025, 12:29 PM   #25
glennpm
glennpm's Avatar
On the inside end of the tube. This basically shortens the effective length of the spring.
Glenn
Rumble Seat’s Notes
Old 07-19-2025, 12:31 PM   #26
cas3
Yes, thank you Glenn for clarifying that!
Old 07-20-2025, 06:51 AM   #27
benbuilder
Thanks for the help.
My spring is 6" long.
This picture show 4 3/4" of spring.
How much should be exposed? It feels like it will work fine at this location,
Old 07-20-2025, 07:41 AM   #28
glennpm
glennpm's Avatar
Ben, your spring is fine. It's not a watch :-) and only there to return the rear shoe position.
Glenn
Rumble Seat’s Notes
Old 07-20-2025, 03:19 PM   #29
petehoovie
petehoovie's Avatar
Old 07-20-2025, 03:31 PM   #30
cas3
I don't see a clip at the end of the tube, is it there?
Old 07-21-2025, 04:02 AM   #31
benbuilder
No clip in the picture. Mine broke.
I took the advice of 19forty from post 19 and got some banding from one of my jobs and made it.
Its on now.
thanks guys
Old 07-21-2025, 05:02 AM   #32
glennpm
glennpm's Avatar
Good!
Rumble Seat’s Notes
