i'm not getting something right in my search query - but i'm sure there's at least one thread.
Q: how did we tow in 1940 [give or take a few years] mostly interested in hitch & receivers as well as trailer construction. thanks s.e. |
Found this, I think back in the day it was either bumper tow or homemade hitches.
https://www.fordbarn.com/forum/showt...wing&showall=1 |
hmmm... so whatever i cobble should be chained to the cobbler.
Military surplus trailers were popular. Sears had some under the name David-Bradley. I've also heard of a Ben-Hur line sold by other stores.
In the 50's My dad had a shop-built trailer that my grandad made, using a salvage axle from a ford pickup. Probably an F1, which had a straight axle similar to the cars, but with longitudinal springs. A towing tongue was welded to the straight axle with triangulated braces of some sort. The trailer bed was about 4'X8' and was attached directly to the axle using a wooden framework and U-bolts to attach. Rough cut oak was used for the trailer bed and sides, which were about 12" high. Tail gate was removable. An army surplus pup tent fit pretty well for my brother and I to use as a makeshift camper.
We used that trailer for everything from gravel/sand to tobacco and hay hauling. It was usually attached to our '51 F1 pickup or the old '46 Case super C tractor with a 5/8" hitch pin similar to those still sold at TSC. Bumper hitch had a hole with no ball. Al Hook |
thanks for sharing. s.e. |
I had one of these neat Mullin's trailers but sold it a long time ago.
https://search.brave.com/search?q=mu...cd34065c8a95dd ![]() SE, all these requests but you haven't shown us what you're actual doing with this. Please share. Thanks
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat’s Notes Techno Source for the 1932 thru 1953 Flathead Ford |
When I was kid (in the '40's), my dad built a trailer. The frame was almost entirely Model "T" Ford. He used the front half of the frame and the front axle (complete with wood-spoke wheels). The frame was bent in and came to a point where the hitch was welded on. The box was about 4X6 and made out of wooden planks with 2X4 framing. Back in those days, a lot of folks had little one-wheel trailers that attached to the rear bumper on two places. When I tried to find a picture of one of these, they were ALL behind Volkswagens. (It must be a cult thing these days). My dad made fun of those guys, because he had a "real trailer". I remember that he had to change to some disk wheels after one of his wood spokes "went south" under a heavy load. He bitched for years that those wheels "cost more than the whole damn trailer".
I have an old cast bumper hitch here some where just like the one GB has on the back of the woody IIRC, I've seen it here in one of his photo postings. No idea where mine is, I moved and I'm not very good at it.
I would search "vintage trailer hitch" on ebay, I'm sure lots will show up |
And....here's my 1947 "modernistic"
#13 |
Storing for what please? You mention "modeling" ???
#14 |
#15 |
I had one for those red CRXs just like yours, bought new when living and working in Texas. Great car especially with suspension mods and headers I put on :-) Super AC too.
Nice trailer! Glenn
#16 |
I love my CRX Glenn. This is the "HF" model, stands for high fuel. Rated at 55 MPG when new, and at 265k I still get over 50 on the hwy. She's not happy pulling the trailer though, local trips only
#17 |
Yes, a great little car!
I went for the "LF" model :-) I had it up to 115MPH a couple of times in my younger days
#18 |
Rambler spindles bolt on to steel flanges. Newc
#19 |
I concur with earlier post on military surplus. Both Willys and Bantam used military tubs and frames and sold trailers under the SPEN and Bantam names. Some trailers were marketed through Sears stores. The military trailers would have the lunette eye and would be connected to a military pintle hitch. The civilian models would have a bolted on Fulton coupler in a under 2" ball size, something like 1 7/8'" The SPEN and Bantam trailers are very popular with the early jeep CJ collectors. The jeeps would have a simple bent plate and ball attached directly to the rear crossmembers.
My current military staff car project would never be expected to tow a trailer, but with the gravel and stone guard and the distance from the rear bumper to the nearest weight bearing cross member would be prohibitive, IMO. So I would look at some sort of direct bumper mount. I don't hink many trailers were used in the civlian marketplace in that time frame and lead to the creation of the station wagon, panel truck and eventually, the SUV. If you needed to tow a trailer, presume it would involve a pick up truck with ball mounted directly into rear bumper as in modern pick up trucks. I have several of the lunette eye shafts where the eye loop has been cut off and a Fulton coupler welded on to use a military trailer, casting, landing leg and safety chains on a modern ball. Good 'ol Bubba. |
#20 |
I'd forgotten that, but they were great to make trailers with. You could use them to make "dropped axles", too. You just had to be sure that you use thick enough plate and gusset it properly when doing so. Ungusseted 1/4' plate ain't thick enough; ask me how I know.
| Thread Tools | |
| Display Modes | |
