Old 07-05-2025, 03:57 PM   #21
mfirth
Default Re: Won't run past 3500 rpm
On the small air cleaners, a friend had a new small air cleaner with the paper element. Swapped the paper one out for a 50s style screen type element & it ran great. Also was mentioned original dizzy. If its an 8BA stock dizzy, it doesn't work well with dual carbs.
mfirth is offline   Reply With Quote
Old 07-09-2025, 06:32 PM   #22
Southtowns27
Southtowns27's Avatar
UPDATE: It runs. I talked to a buddy that races a flathead at TROG and the like. He mentioned that his magneto had a tendency to burn the cores out of spark plugs and it'll act just like I described. I thought no way, but I was running a 60,000V coil, relatively high compression, and a large-ish plug gap. So what the heck, I threw a new set of plugs in it, put a stock coil back on, tightened up the gap and now it rips. The old plugs don't have continuity through them measured with a multimeter. I've never seen that before and would have NEVER guessed that was the issue. They look perfectly fine (not fouled, etc) but they're 100% bad...
Southtowns27 is offline   Reply With Quote
Old 07-09-2025, 07:26 PM   #23
KiWinUS
KiWinUS's Avatar
Fantastic. Stock ford ignition systems for the most part are Great.
Old 07-10-2025, 08:47 AM   #24
Tim Ayers
Awesome. Great news.
Old 07-10-2025, 04:57 PM   #25
tubman
tubman's Avatar
It's great that you found it. We used to have the same problem with 2 cycle snowmobile engines. All of a sudden, one cylinder would start running sour. We'd pull the plug, and when we looked at it, it seemed perfect. However, if we replaced it with a good plug, and it would run like gangbusters. A friend of mine had a spark plug cleaner and tried to resurrect several of these"dead" plugs; to my recollection, they just wouldn't come back.
