#21 | |
Something else did catch my eye, though, something that most rodders never consider... you mentioned two piece seats? I take that to mean buckets? Don't for a minute think that any seat replacement could be anywhere near as comfortable as your stock Ford/Mercury seats of the era. Think twice before replacing your armchair luxury.
Alan |
#22 |
[email protected]
Keith Lee Keith makes great reproductions of knobs/steering wheels/horn button/etc. He made a '40 MERC button spare for my car. My son has my ' 40 4door convertible now. Love the car. Do you have the air heater? They are being reproduced now. Clem |
#23 | |
That's a fantastic question, can you ask me a different one? |
#24 | |
#25 | |
https://bringatrailer.com/listing/19...-coupe-custom/
#26 |
#27 |
I know i saw some adapters for a compressor on speedway. But the Radiator is the bigger issue. I found some with condensers but not with the correct ports. So i am on the lookout for those still.
#28 |
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat’s Notes Techno Source for the 1932 thru 1953 Flathead Ford |
#29 |
https://www.fordbarn.com/forum/showp...4&postcount=14
Default Re: air conditioning on a flathead? I put A/C on my 40 Ford more than 10 years ago. I have driven anywhere I desired without engine overheating regardless of the terrain or temperature. That includes over the Rocky Mountains, in August, to Bonneville from southern Georgia. That trip was with STOCK Ford waterpumps and STOCK Ford radiator. I installed a blow-through electric fan on the condenser to help the exchange rate at low speeds to provide cold air from the A/C. The fan is not used at highway speed and it is a restriction to maximum air flow. But, still NO OVERHEATING. I have since changed to a Walker radiator with their condenser because the stock radiator braces repeatedly broke loose from the top tank. I think the extra weight of the condenser and blow-through fan contributed to the breakage. I still have the stock waterpumps in place. I suggest the Walker radiator with their condenser because the recovery rate of the radiator is superior and the condenser is a nice arrangement. I built my brackets and special reinforcement gadget at the front of my aluminum intake manifold. These days there are brackets advertised in magazines(as noted above) and they should work OK. I would only add that some aluminum intake manifolds are not well designed at the generator mount so they might not handle the additional loading. The Edmunds on my car was one such example. |
#30 | |
#31 |
About a decade ago one of the local car club members in Houston restored a 41 Mercury sedan and added air conditioning using the Vintage Air mounting kit. The engine ran hot. He found he had to make brackets and move the condenser forward of the radiator, towards the grill. After moving the condenser everything was good. He sold the car after his wife quit riding with him on tours.
The car is now owned by friends of mine in central Texas, the wife drives the car daily to work even in the summer. The point is you can have a mostly stock Mercury that runs on pump gas, goes reasonably fast (65 with stock gearing, 80+ with overdrive), and has air conditioning. As everyone above has said, you need to plan ahead, but it is worth it when everything works out. |
#32 |
There was a '52 or so Ford pickup at Springfield - flathead with air. Did not look at setup close. I was likely getting too hot at the time with temp in the high 90's.
TomC750 1949 8NV8 Ford tractor 1930 1 Ton White 1941 Mercury Sedan Coupe |
#33 |
Knob Soup [email protected] Lee https://www.youtube.com/watch?v=IESeHql
Keith does great work on knobs and horn buttons and steering wheels Clem |
#34 | |
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
#35 | |
#36 |
Dont blame ya. Heat can be brutal.
#37 | |
#38 |
Me either. I love these stock seats.
#39 | |
#40 | |
The second reason is when looking at rebuild kits for wheel bearings and seals, there were kits under the '39-40 Merc section that were optioned for mechanical brakes and hydro brakes.
| Thread Tools | |
| Display Modes | |
