Old 06-25-2025, 08:47 PM   #1
Granny
Default Pickup Bed
I am wanting to put a plywood floor in my pickup and have a couple of questions.
What ply would be best used?
Do you have to have a gap all way around it for expansion if so how much?
Granny
Granny is offline   Reply With Quote
Old 06-25-2025, 08:50 PM   #2
rawlir
Default Re: Pickup Bed
Are you using skid strips? What year of pickup?
rawlir is offline   Reply With Quote
Old 06-25-2025, 08:51 PM   #3
Model51
Model51's Avatar
Granny,
The best match to the original floorboard material for your pickup is somewhat dependent upon what year pickup you have. Also, if your pickup was assembled in Australia, then it's going to be a product that was locally available at the time your pickup was produce. So share which year and version of pickup you are working on.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 06-25-2025, 09:22 PM   #4
Joe B.
Joe B.'s Avatar
If you want durability, I would use exterior grade underlayment plywood like in the link. It has thick plies, not a super thin veneer surface that won't last.https://www.lowes.com/pd/Plytanium-2...x-8/1000068939
thread killer
Joe B. is offline   Reply With Quote
Old 06-25-2025, 11:13 PM   #5
Karl Wescott
Karl Wescott's Avatar
IMHO a solid piece of plywood is asking for trouble. It will be difficult to keep moisture out of the plywood unless the truck is inside 100%. The original design of planks separated by the rub strip bolts allowed air to circulate on the sides of the planks which I believed slowed the rotting process. Humble belief from wet western Oregon.
Karl Wescott is offline   Reply With Quote
Old 06-26-2025, 08:30 AM   #6
Kube
Super Moderator
Kube's Avatar
Without question....spot on advice. I'd use white oak, KILN DRIED!
Old 06-26-2025, 09:38 AM   #7
19Fordy
19Fordy's Avatar
Granny: Plywood will hold moisture warp and rot and look terrible in a short amount of time. Use "Kube's" suggestion.
LOOK HERE: https://www.bing.com/search?q=how+to...ANAB01&PC=HCTS
19Fordy is online now   Reply With Quote
Old 06-26-2025, 09:58 AM   #8
Krylon32
I did a solid floor in a couple 32 boxes I built from scratch and used a sheet of kiln dried
clear some kind of plywood that had a marine designation. Sold the trucks without the box ever getting wet so I have no feedback.
Krylon32 is offline   Reply With Quote
Old 06-26-2025, 10:28 AM   #9
petehoovie
petehoovie's Avatar
Old 06-26-2025, 11:20 AM   #10
Kube
Super Moderator
Kube's Avatar
Or like Ford did it...
Old 06-26-2025, 12:50 PM   #11
terry
This is how it was done on my 48 Ford pickup. Metal entirely covered the top of the wood.
terry
terry is offline   Reply With Quote
Old 06-26-2025, 05:08 PM   #12
Krylon32
My daily driver deuce pickup still has the steel over wood floor and other than normal wear and tear the floor is as solid and looks as good as when it was originally made.
Old 06-26-2025, 08:15 PM   #13
Granny
the pickup I am working on is a 1938 Aussie built Ford
Old 06-29-2025, 09:51 AM   #14
Bob NH
Bob NH's Avatar
Picture that Kube shows is about what my 35's had, maple under the steel pan
Bob NH is offline   Reply With Quote
Old 06-30-2025, 07:44 PM   #15
Granny
Would marine plywood work in place normal plywood
Old 07-01-2025, 03:54 AM   #16
s.e.charles
s.e.charles's Avatar
yes; more better too.
but if you're serious about plywood in any configuration, seal the edges (marine or not).
s.e.charles is offline   Reply With Quote
Old 07-01-2025, 02:51 PM   #17
ronn
pressure treated- but only if stored inside.
Old 07-01-2025, 08:56 PM   #18
GB SISSON
GB SISSON's Avatar
Are you referring to pressure treated lumber or pressure treated plywood?
Old 07-02-2025, 07:43 PM   #19
New2restoring
Marine plywood AA rated, then treated as well
New2restoring is offline   Reply With Quote
