Old 06-20-2025, 11:00 AM   #1
Vic in E-TN
Question Muffler Floor Insulation
I have a few of these from Leslie Pam on my cars and need another one. I cannot find his contact anywhere. Is he still in business and does anyone have his contact information?
Thanks,
Vic
Vic in E-TN is offline   Reply With Quote
Old 06-20-2025, 12:05 PM   #2
Mel Gross
Default Re: Muffler Floor Insulation
Leslie Pam
310-275-3836
Mel Gross is offline   Reply With Quote
Old 06-20-2025, 02:34 PM   #3
David in San Antonio
David in San Antonio's Avatar
What is muffler floor insulation? A fabric?
Late ‘30 Deluxe "Wretched Roadster"
1931 Slant Windshield Fordor “Earl Gray”
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 06-20-2025, 02:53 PM   #4
Vic in E-TN
David:
His product is a metal shroud that covers the top of the muffler and comes around the sides at a 45 degree angle. It is held on with U-clamps in front of and behind the muffler. It really works.
Vic
Old 06-20-2025, 04:05 PM   #5
Bruce of MN
Bruce of MN's Avatar
Or make your own
I used muffler clamps, coupler nuts, and something like
https://www.lowes.com/pd/IMPERIAL-12...k-Duct/3307288
Old 06-20-2025, 04:30 PM   #6
Ruth
Thanks,
Vic
There is an ad in the Model A News for Leslie's "Kool-Feet" insulated muffler shield.
Ruth
Old 06-20-2025, 05:08 PM   #7
JayJay
I got a couple from him last summer. At that time he said he was getting out of that line and once his stock was gone, that's it. His email address is [email protected].
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 06-20-2025, 09:43 PM   #8
This is great news! One of the club members gave me one of these when I first joined and it’s still sitting on the shelf in my garage. Yee hah!
Alamo A’s Club
Old 06-21-2025, 06:15 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
Most heat (75%+) transfers by radiation, so a reflective metal shield is an effective way to block the heat. Here is my inexpensive and easy to do technique.
File Type: jpg 190A Floor Board w Heat Reflector Mod 347kb.jpg (32.1 KB, 95 views)
Bob Bidonde
Old 06-21-2025, 10:17 AM   #10
Ruth
What's the hole in the passenger side for? Perhaps checking trans oil?
Ruth
Old 06-21-2025, 10:58 AM   #11
32Ford13
I've used products from this company for years. Outstanding stuff. My wife complains now that she can't warm her feet on the floorboards with their stuff installed. If you have questions call Mike Z for tech support. Super smart guy.
https://www.designengineering.com/
32Ford13 is offline   Reply With Quote
Old 06-21-2025, 03:47 PM   #12
rotorwrench
rotorwrench's Avatar
The caveat to adding more weight to the exhaust is that it puts more strain on the exhaust manifold. They tend to warp and slump over time without adding further weight. If they just had a forward support, they would be fine but Ford didn't make it that way.
Old 06-21-2025, 06:23 PM   #13
Synchro909
Synchro909's Avatar
I've posted a number of times how I overcome that. I use a spring, hose clamp and a piece of wire to connect the exhaust just in front of the muffler to the engine mount. I realise that is not for the show car but I drive mine (lots).
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 06-21-2025, 07:42 PM   #14
Ruth
Do you use a heavy spring such as a brake spring. Sounds like a good idea i may try.
Ruth
Old 06-21-2025, 11:35 PM   #15
Synchro909
Synchro909's Avatar
Yup, something like a brake spring. I am a bit of a horder so there is a tin of springs in the workshop. I just selected one that I thought would be about right. The tension can be set when you tie it to the muffler by playing with the length of the wire.
Old 06-22-2025, 08:16 AM   #16
nkaminar
nkaminar's Avatar
My car has a layer of insulation between the floor boards and the carpet. It came with the heat shield but I found that it did not make any difference and rattled. So I took it out and gave it away.
Old 06-22-2025, 09:03 AM   #17
katy
katy's Avatar
Ditto
Old 06-22-2025, 10:11 AM   #18
nkaminar
nkaminar's Avatar
My car's floorboard on the starboard side has the same hole. My transmission has a piece of pipe in the hole that is used to fill the transmission. At the top of the pipe is a pipe cap with a hole to allow an engine dip stick to be used. It makes it easy to check the oil and add oil.
Old 06-23-2025, 06:24 AM   #19
Bob Bidonde
Hi Ruth! The extra hole on the passenger's side of the floor is to make it easier for my 82-year-old body to service the transmission oil.
Bob Bidonde
