Hi. I have been rebuilding my 34 trans for my fordor so it’s been start and stop over a couple a months over getting time and getting parts. Thought I was finishing it off today.
All seemed good, before I had the front bearing retainer tight just snug, put the shifter in tested the gear shifting , seem to work good, pulled shifter back out, tightened up front bearing retainer, then noticed it’s snug to turn by your hand now to snug grab a rag and twist pretty good by hand. Slack it off a bit, not much, turns over nice feels like it should. Bought all my parts pretty much from Mac at Vanpelt sales and a few nos pces. So pretty confident everything is correct there. So I must have done something or missed something. Before I start to dismantle thought I would throw it out there and see what the most likely cause would be ? Something I missed or did on the main shaft assembly I am assuming . Thanks in advance. |
I don’t know maybe there is nothing wrong it’s just snug thought it would be a little looser to turn , maybe it’s the difference in gasket thickness I’m just not sure , just a little tighter than I am use to say with Muncie type four gear.
Is the u joint tightened up?
that pulls the main shaft tight to the rear bearing. |
I don’t have the u joint portion on at this time only the retainer
Should spin freely
I will try my pinion torque wrench and see what it reads |
If I put my pinion torque wrench on the nut through the u joint it takes 25 inch pounds to turn it . About the preload of a diff. Is that slightly tight ?
Can you wiggle the synchro back & forth a little? Sometimes the brass cone will grip the main drive gear enough to drag
I have currently have it all buttoned up so can’t wiggle it right now
Is it dry in there or have you added some lubricants?
All good advice above, pull the top cover, make sure the brass rings are not stuck, and oil things up
Yes everything is all oiled up and I did shift through the gears I will put the shifter back in it tomorrow and do it again and see how it acts, but yes used assemby grease in areas and poured some oil I rotating the gears before putting the top on.
Thanks everybody appreciate it |
#13 |
25"/# is too much. Is the transmission in neutral or in a gear? How does it turn in neutral?
#14 |
Yes that is neutral
I would have to agree it just seems a little to tight I just loosen off bearing retainer on either end a bit and it makes a noticeable difference and turns more like I think it should. |
#15 |
Just to be sure - stock ‘34 transmission? Do you have the oil baffle on the main drive gear? The early synchro is not held by a snap ring and should slide back and forth easily about 1/8”. If it hangs up on the main shaft that can be a problem. We don’t put assembly grease on the brass surfaces as it makes them grab sometimes, but we do spray with a thin lubricant called “power lube”.
#16 |
Hi yes stock 34 transmission, Yes I remember correctly yes on the oil baffle
On the grease, I use a lighter one made by driven that I use for engine bearings during assembly. I put a new synchro in it and seems to me it was hanging up at first until it was moving freely. Would It be worth trying the shifter , turning trans by hand and going through the gears see if it frees it up ? Thinking to try a few things like that before I tear things apart which I am hoping not to have to do. It does turn smooth just tight Thx |
#17 |
I would remove the shift tower and make sure the synchro is moving freely - not hung up on the main drive gear or second gear cone. Put the slider in neutral and then see how it feels. Do you have gaskets at the front & rear retainers?
#18 |
Ok I will do that thanks. Yes I have thin gaskets at each end , and it seems like if I doubled one gasket up it would about the right amount of clearance seems like it’s about that close to be correct in my mind.
#19 |
Pics would be helpful. Are you using the early front retainer (original) or the later one with the seal (78)?
#20 |
I am using the original earlier one with out the seal I will see if I can figure out some pictures thx
| Thread Tools | |
| Display Modes | |
