Old 05-22-2025, 08:16 PM   #1
RGC1
Default Differences between 34 and 35 car chassis
I am just wondering if you can tell me what the differences are between te 1934 and 1935 passenger car chassis ?
Thanks in advance
RGC1 is offline   Reply With Quote
Old 05-22-2025, 09:01 PM   #2
Charlie Stephens
Default Re: Differences between 34 and 35 car chassis
This might be a good place to start: wescottsauto.com
Charlie Stephens
Old 05-22-2025, 09:08 PM   #3
tubman
tubman's Avatar
I think this may be one of those "If you have to ask, the answer won't do you much good." situations.
Old 05-22-2025, 10:53 PM   #4
RGC1
Not sure what that is suppose to mean, just wanted to know if they were made the same for a couple years or if there were big differences in the year change Wanted to buy some spare parts for my 34 and seen a 35 chassis for sale , thought I might buy it if it was the same frame as a 34.
Thanks
Thanks I will check westscotts
Old 05-22-2025, 11:01 PM   #5
alchemy
alchemy's Avatar
Close if you squint, but way different if you open your eyes.
alchemy is offline   Reply With Quote
Old 05-22-2025, 11:40 PM   #6
cas3
35 to 40, basically the same. 33-34, basically the same. 32- one year only.
The 35 frame will do you no good for a 33-34 car.
Old 05-23-2025, 07:11 AM   #7
rockfla
rockfla's Avatar
The wheelbases are the same 112" but the 35 is a little over 6-1/2 longer due the front axel and forward mounted spring that allowed the engine and transmission to be moved forward in the chassis thus giving more interior room. The body width was also 2-1/2 wider.
Old 05-23-2025, 07:23 AM   #8
Dave G
Guest
Posts: n/a
Enough to say most everything.
David J here .
Changed emails and cannot get back into my old account.
Support has not been able to fix it so far so newbie i guess.
Old 05-24-2025, 09:59 PM   #9
danliveshere
danliveshere's Avatar
As already mentioned above they are nothing alike. Dan.
danliveshere is offline   Reply With Quote
Old 05-26-2025, 01:29 PM   #10
s.e.charles
s.e.charles's Avatar
did Wescott's get bought out or change ownership?
this is as close as i could get: http://allfordparts.com/shop/vendor/wescotts
s.e.charles is offline   Reply With Quote
Old 05-26-2025, 05:13 PM   #11
TJ
TJ's Avatar
Karl Wescott posts here frequently. Do a name search and the posts should show up. You can send him a private message.
Old 05-27-2025, 07:08 AM   #12
deuce lover
deuce lover's Avatar
Here
Wescotts Auto Restyling
Wescotts Auto
http://www.wescottsauto.com
Old 05-27-2025, 03:18 PM   #13
s.e.charles
thanks for the help & correct link deuce lover.
as entertaining as some of the prior comments were, i don't see them helping the original poster much.
Old 05-27-2025, 04:39 PM   #14
rotorwrench
rotorwrench's Avatar
The 1935 frame was a new design even though it is similar to the 1933/34. The basic 1935 design was changed in small subtle changes for nearly each year up to 1940 and early 1941 for the commercial pickup. The basic shape was still there but there were changes to body mounts and bolt holes. Early changes to the front and rear drive train mounting plus the 1939 Deluxe and 40 models were changed for the front mountings due to the crankshaft mounted fan and new radiator. Wescott's has all the dimensions and lists the differences by year grouping on their drawings.
Old 05-30-2025, 09:30 PM   #15
RGC1
Thanks for all the replies , very much appreciated
