Old 05-12-2025, 03:21 PM   #1
Dragfink
Dragfink's Avatar
Default Part ID
Gentlemen, what’s the actual name for this part?…it goes side-to-side, quarter panel-to-quarter panel, underneath the panel below the deck lid…
Thanks
Dragfink is offline   Reply With Quote
Old 05-12-2025, 03:35 PM   #2
Marshall V. Daut
Default Re: Part ID
I've just always called it the rear lower body crossmember. Model A people seem to respond to that name.
Marshall
Marshall V. Daut is offline   Reply With Quote
Old 05-12-2025, 04:14 PM   #3
alexiskai
alexiskai's Avatar
Default Re: Part ID
Rear cross sill, I thought.
Old 05-12-2025, 04:19 PM   #4
Marshall V. Daut
Default Re: Part ID
That would work, too. I like your designation better than mine. It's crisper.
M.
Old 05-12-2025, 08:11 PM   #5
mcgarrett
Default Re: Part ID
Lower rear valance panel.
Old 05-12-2025, 08:52 PM   #6
Marshall V. Daut
Default Re: Part ID
"Lower rear valance panel."
Not to split hairs over a semantics issue, but I believe that would be more accurately applied to the unique rear valences found on Fordor sedans, Victorias, Deluxe Phaetons and Convertible sedans. The piece Dragfink is asking about is found on Tudors, roadsters, phaetons, Cabriolets and coupes of all flavors.
Marshall
Old 05-12-2025, 09:46 PM   #7
Jim Mason
Jim Mason's Avatar
Default Re: Part ID
From service bulletins
File Type: jpg Screenshot_20250512_214427_Adobe Acrobat.jpg (52.5 KB, 85 views)
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 05-13-2025, 04:10 AM   #8
Marshall V. Daut
Default Re: Part ID
Jim has settled the issue for us with irrefutable documentation from the horse's mouth, as it were (i.e., from FoMoCo). However: "A rose by any other name... etc., etc." I do think that a Model A guy would understand what was meant by any of the names suggested so far, or at least recognize the general area where that part lives.
Marshall
Old 05-13-2025, 07:42 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
Default Re: Part ID
The part is called a "Sill Assembly" in Ford Body Parts Price List. See the diagram on Page 233. The part number is likely to be A-45050 Sill (floor cross) center-rear and it is common to the 45-A Coupe, 45-B Coupe, 49-A Special Coupe, 50-A Sport Coupe, 50-B Sport Coupe & 54-A Special Coupe.
Bob Bidonde
Old 05-13-2025, 09:14 AM   #10
Dragfink
Dragfink's Avatar
Default Re: Part ID
Thank you gentlemen
Old 05-13-2025, 11:19 AM   #11
Jim Mason
Jim Mason's Avatar
Default Re: Part ID
Marshall
Yup
Fwiw, jm.
Old 05-13-2025, 01:57 PM   #12
Randy in ca
Randy in ca's Avatar
Default Re: Part ID
The Sill pictured in post #1 is not the version to fit all the Coupes (or Roadsters) it is for Tudor Sedans and possibly Phaetons (forget for sure on Phaetons without checking). The shape on the ends is totally wrong for Coupes and Roadsters (except as that shown in the third picture). Edited to add picture from Mike's.
Randy in ca is offline   Reply With Quote
Old 05-13-2025, 03:29 PM   #13
Karl Wescott
Karl Wescott's Avatar
Default Re: Part ID
The tudor sedan sill rear crossmember (iirc) fits the four-door (35A, 35B) phaetons. It does not fit the 1930-31 tudor (180A) phaeton.
The bodies that used a "rear valance panel" were mostly bodies that had a wood sill structure (1931 fordor the exception), though I prefer the term "back splash apron".
Karl Wescott is offline   Reply With Quote
Old 05-14-2025, 04:07 PM   #14
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Part ID
So since this has been answered correctly let me ask a question relating to this.
Do you think we are doing any harm, -or doing a disservice to the hobby by using made-up or confusing nomenclature for names on different parts? Especially for parts used in other Countries?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-14-2025, 04:45 PM   #15
Karl Wescott
Default Re: Part ID
Interesting conundrum. IMHO in general, using the specific Ford terminology would be best, however sometimes to a "lay" person this could be confusing. Most customers would think a "lock" is something you insert a key into to allow function, however what most would call a door latch Ford called a door lock. The second issue is where Ford's nomenclature is unclear or unknown to the user, the "valance" vs "back apron" as an example, or what I call a "clutch spring" internal to a window regulator (Ford did not service the internals to the regulators as far as I know) as that is my best description as to its function.
Old 05-14-2025, 05:01 PM   #16
alexiskai
alexiskai's Avatar
Default Re: Part ID
The parallel use of a formal and a vernacular language for the description of some set of objects or ideas is pretty common.
Sometimes the vernacular term arises because the formal term is unwieldy or unintuitive. For example, the rear cabin window is usually called the rear light in technical documents, but who calls a window a light?
Another reason for a vernacular term to arise is to distinguish something that the formal language doesn't distinguish. For example, if I say "the #8 stud," most of you know that I mean the longer cylinder head stud to which the ignition cable is clamped. But of course that term relies on a numbering system that originated in the hobbyist community decades after production ceased.
Lastly, vernacular terms arise because the formal term is not commonly known or accessible. Because technical diagrams and factory descriptions, particularly of subassembly parts, are sometimes not available or were not available until recently, the community sometimes has to invent names for them. I'm thinking of the collar that sits on the shaft of the Model B distributor and is pivoted by the counterweights to advance the cam. I'm not really sure what the official name for that is, in part because it was always sold as a full assembly with the shaft, weights, and springs, and I don't have access to the drawing for that assembly.
However, because of the fragmentation of the hobby, it often happens (as seen in this thread) that there's no consensus on what the vernacular nomenclature for some things is. In addition, everyone has to learn all the words as they go, and there's often a tendency to re-use terms for things that have a similar function if no one is around to tell you the exact name. For example, there are a lot of things commonly called "control rods" that are very different from each other but are similar in being a component in a linkage. So I think it's reasonable to offer corrections when it appears that the use of vernacular terms is engendering confusion, but if a vernacular term is doing its job of signifying a particular thing (e.g., "RPU") then I don't think people should be chastised for using it.
Old 05-14-2025, 06:20 PM   #17
nkaminar
nkaminar's Avatar
Default Re: Part ID
Other names commonly used: Dohicky, thingamabob, whatsitcalled. Can you add to this list?
Old 05-15-2025, 08:13 AM   #18
Bob Bidonde
Default Re: Part ID
Model "A" parts & processes the world over have many many jargon names such as wish bone, banjo housing, tranny, crank, popout, perch, carb, aprons, speedo, Japaned, Pitman, drag link, slinger, Bendix, etc. We have a habit of calling parts the way they appear to us or by their makers names. Also, in languages other than English, the vocabulary will mandate alternative names of stuff. So on public forums, we ask for pictures of parts with jargon names to be sure we know what is being discussed. I do not see any negatives from using jargon in this way.
Bob Bidonde
Old 05-15-2025, 06:47 PM   #19
David in San Antonio
David in San Antonio's Avatar
Default Re: Part ID
I’m firmly in the camp of describing parts in detail using as many names and descriptors as are known, with labeled diagrams, clear photos, and examples.
Why?
The Model A hobby attracted me in part because I love the feeling of confidence I get when I know I can do basic repairs. I previously had a Haunted Audi which was so complex and computerized that I couldn’t address even small problems, and everyone who specialized in German cars charged more on a per-hour basis than a private college in New England. I finally gave the darn thing it away, literally for free. Hence the urge to drive and fix a Model A.
At this stage I am undertaking every task for the first time.
When a repair instruction refers to parts without pointing them out in a diagram nor describing them I sometimes get anxious and frustrated because I really, REALLY don’t want to screw it up.
Recent example: I’m fixing the horn which suddenly went silent. Les Andrews Red Book: “Remove the connector block screw, nut, and washers and lift the connector block from the mounting base.” This is accompanied by two diagrams, but neither points out a “connector block” nor “mounting base”. I fumbled around and disassembled something else (I’d call it the adjuster mechanism) and realized that isn’t it. Also find the book doesn’t have an exploded diagram of the adjuster assembly which is now in pieces. I will figure it out or find another source. Finally I did find and remove the connector block. Now I realize it CONNECTS the electrical leads to the horn circuit. But it isn’t a block, certainly not like the distributor points rubbing block.
Simple in retrospect, and I’ll know it for next time, and I didn’t destroy anything, but wow a few extra words and an arrow would have made it easier, quicker, and not frustrating. The next step refers to removing the “ratchet tension clip” with no indication of what it is. This one I figured out with less agony.
I am not knocking Les Andrews’s books. As a technical writer I know that creating instructions means striking a balance between usability versus complexity and is restricted by the size of the document. I guess his intended audience is not the complete newbies like me.
What I have learned is to take deep breath, slow down, summon wise patience, and take pictures of everything at every stage. When in doubt, call club members for advice and post the question here on FordBarn. Crying, shouting curses, and taking a slug of bourbon May feel better at first but ultimately does not enhance my ability to reason.
Late ‘30 Deluxe "Wretched Roadster"
1931 Slant Windshield Fordor “Earl Gray”
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
