Old 07-13-2011, 09:31 AM   #1
leo
leo's Avatar
Question Pinstripe Using 3M Scotchcal Tape
Has anyone used this product on their Model A? The video shows it to be very easy to work with. Opinions?
leo is offline   Reply With Quote
Old 07-13-2011, 09:36 AM   #2
LukeDahlinger
Default Re: Pinstripe Using 3M Scotchcal Tape
While I haven't used it on Model A's or other early car, I have used it a great deal on modern iron.
It's good for what it is, but it's no substitute for painted stripes- plastic striping sticks out like a sore thumb on a Model A.
Wanted- Feb. 1931 Parts Price List
www.vintagefordfacts.blogspot.com
LukeDahlinger is offline   Reply With Quote
Old 07-13-2011, 10:11 AM   #3
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Why not use the Finesse tape with the peel off center and paint the stripe then peel off the temporary border tape. Works well and more authentic than permanent tape.
Barry B./ Ma. is offline   Reply With Quote
Old 07-13-2011, 10:21 AM   #4
leo
leo's Avatar
Barry, is the Finesse tape easy to work with? When you peel it off does it leave a sharp edge?
Old 07-13-2011, 11:32 AM   #5
foxfire42
foxfire42's Avatar
Is it flexible enough to made the curves inside on the gas tank?
foxfire42 is offline   Reply With Quote
Old 07-13-2011, 02:13 PM   #6
29FordGuy
29FordGuy's Avatar
I used the Finesse on my town sedan and think it really looks nice. The important point is to remove the tape right away before it dries so that the edge rounds over and is not so sharp. As for the gas tank design, I tried a couple of times but could not get a good curve on the corners. The tape stretches some but these corners are too tight. I finally ended up using the tape for the straight runs and doing the corners by hand using a very small brush I got at a art store. I think it was a good alternative to a more expensive hand pinstriping, but I am sure a pureist would see the difference. Good luck.
29FordGuy is offline   Reply With Quote
Old 07-13-2011, 02:44 PM   #7
rogerkb1936
rogerkb1936's Avatar
i have a system that is time consuming but is likely as close to hand done as you can get. too lengthy with my typing, you can call 360 674 3130 and i will explain if you like.
rogerkb1936 is offline   Reply With Quote
Old 07-13-2011, 02:46 PM   #8
Mitch//pa
Leo,
not sure of what kind of look or quality of job your after but i have a guy in the area that is a fantastic free hand paint stripper and reasonable.
Old 07-13-2011, 03:50 PM   #9
Louis
Leo,
If you have a nice looking "A", Do it right and find some one who hand paints it, It may cost more but it's well worth it. You won't be sorry.
Louis is offline   Reply With Quote
Old 07-16-2011, 01:02 PM   #10
Gary Gregory
Gary Gregory's Avatar
Can you get Finesse tape at the local parts store ?
Gary Gregory is offline   Reply With Quote
Old 07-16-2011, 02:22 PM   #11
29FordGuy
29FordGuy's Avatar
I got mine at TCP Global ...
http://www.tcpglobal.com/pinstriperd...sdfinesse.aspx
They also have paint, brushes and whatever else you may need. I did not have any luck locally but I live in a very small town. You could also do your curves by using 3M fine line tape. It is flexible and will make the corners with effort but you need to tape each side of the stripe separately.
Good luck.
Old 07-16-2011, 07:34 PM   #12
glenn in camino
glenn in camino's Avatar
Mix your stripe color with One Shot lettering enamel. Get a professional sword brush and practice striping. It's not that hard. Wipe off mistakes with mineral spirits and try again. You can do it.
Old 07-16-2011, 07:42 PM   #13
RHD
RHD's Avatar
I think any pin stripe with tape on a Model 'A' is simply "horrible". Why not go to a
little more expense and have it done by hand as it is meant to be. Even better still, have a go at pin striping yourself. I did. If I can do it, any body can.
R.H.D.
Silence is golden unless you have kids, then silence is suspicious.
RHD is offline   Reply With Quote
Old 07-16-2011, 09:34 PM   #14
LukeDahlinger
Striping freehand isn't that hard with the right brush. That's the key is using the right brush and knowing how to load the brush properly. I don't do alot of pinstriping, just on cars that I paint.
If you do a search on Google Books for pinstriping, you can read several books on the topic for free.
Old 07-16-2011, 10:12 PM   #15
29FordGuy
29FordGuy's Avatar
I seriously considered doing the pinstriping myself - getting the right brush and practice, practice, practice, but decided to try the tape and was very pleased. The key I think is removing the tape very soon after applying the paint so that the edge rounds. I do not think it is awful looking and have had many many good comments on it. Maybe if there is a down side to the tape it is because the edge and thickness of the line is too perfect. If I did it by hand I know it would have more irregularities. But, the biggest reason I chose to go with the tape is that I do not have the steady hand that I used to when I was younger. It is a curse of old age! So I think that both techniques can produce a very fine job and if you can do it by hand yourself then I envy you. And if you need to resort to the tape, then that is fine too. To each his own .....
Old 07-16-2011, 10:50 PM   #16
LukeDahlinger
My secret is a couple slugs of whiskey before I begin. Smooths the nerves right out, and lets me lay down a good straight line.
Henry Ford didn't drink and hated anyone who did drink(with exception), but the pinstripers were the only people permitted to drink on the job!
Old 07-16-2011, 11:03 PM   #17
29FordGuy
29FordGuy's Avatar
There you go .... I never considered that! I would like to try pinstriping by hand on my car trailer I just got so will keep that in mind. Might be worth a try. That is interesting about Henry and the pinstripers. Is is really true? BTW your pinstriping you did on your car is beautiful. You did a worderful job. I should take some pics of mine to post.
Old 07-16-2011, 11:25 PM   #18
Mike V. Florida
Mike V. Florida's Avatar
I can see it now,
Honey how come the Jack Daniels is almost empty?
Well Dear, I just practicing my pin striping.
Old 07-17-2011, 12:26 AM   #19
Bob from Northport
Bob from Northport's Avatar
Since you live in N. Jersey, there is a guy that lives on Long Island named Jim Brand. He does absolutely the finest pinstriping in the country, and is a veritable encyclopedia on Model A's. He knows everything there is about pinstriping these cars, and you won't be sorry. Call him. 1-516-922-1892
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 07-17-2011, 02:08 PM   #20
Roger Ball
Speaking of factory pinstipers, I recall seeing a couple original photos on-line of pinstriping being done on the assembly line, but cannot find them. Does anyone know where I might find them again? I recently had my '30 Sport Coupe striped, and the guy who did the work would really enjoy those pictures.
Roger Ball is offline   Reply With Quote
