Old 03-17-2025, 02:50 PM   #1
Gary WA
Gary WA's Avatar
Default Double Venturi carb Before/After
Double Venturi Bowl half before and after cleaning up! Lots of heat/windex and cold water.Bead blasting.
www.whidbeymodelaclub.com
Old 03-17-2025, 03:35 PM   #2
Dave in Petaluma
Dave in Petaluma's Avatar
Default Re: Double Venturi carb Before/After
Gary, where will you find a new venturi for that carb?
Dave in Petaluma is offline   Reply With Quote
Old 03-17-2025, 04:20 PM   #3
Gary WA
Gary WA's Avatar
I have a few and I did that one for someone else who has one. They were available thru the vendors but supply is out.!
Old 03-17-2025, 06:41 PM   #4
Synchro909
Synchro909's Avatar
Does a single venturi fit the housing?
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
If I am not in trouble, I've done something wrong.
Old 03-17-2025, 08:17 PM   #5
Gary WA
Gary WA's Avatar
yes they will,read where they were changed in late 1928 because mechanics were breaking them when taking apart so changed to single venturi. never tried to run a DV with single not sure on the operation.
Old 03-17-2025, 10:15 PM   #6
lrf
Gary, were there original jets in this double venturi carb and what were they numbered/sized? Didn't Holley/Zenith change them a few times? I ask because I have some jets and don't know for sure what number Zenith (1 or 2) to stick them in. Also, your article on secondary carb wells printed in the national mag was great! Thanks LRF
lrf is offline   Reply With Quote
Old 03-18-2025, 03:47 AM   #7
johnbuckley
johnbuckley's Avatar
Originally jets were numbered replacements generally aren't. Flow testing is the only way to ensure accuracy of jets; various articles elsewhere on Fordbarn about that topic!
If going by numbering Idle usually 10 or 11, Main19.5 or 20, Comp 18 or 19, Cap 19, 20, or21 jets are interchangeable on SV and DVs and Zeniths I and 2 and Holleys lookalikes ,
Old 03-18-2025, 03:47 AM   #8
johnbuckley
I have run DVs in "single venturi" housings and vice versa and detected no difference in performance or economy. You may need to grind the locating dowel off if fitting a SV to a DV housing.
Old 03-18-2025, 06:31 AM   #9
nkaminar
nkaminar's Avatar
I read somewhere that the double venturi was dropped because of a patent dispute.
Old 03-18-2025, 08:20 AM   #10
Jim/GA
Jim/GA's Avatar
Stromberg vs. Zenith April 1928
https://casetext.com/case/stromberg-...nith-detroit-2
Jim Cannon
"Have a Model A day!"
Old 03-18-2025, 05:46 PM   #11
Synchro909
Synchro909's Avatar
Good stuff. Thanks guys. I have a KTK carburettor which is DV. I'd like to get it going - just coz. IMO a Japanese carburettor on the Model A would raise a few eyebrows.
Old 03-13-2026, 12:43 AM   #12
RENNERS CORNER
RENNERS CORNER's Avatar
Holley / Zenith Double Venturi.... found another core to assemble and run. Here again someone removed the locator / indexing pin. The pin is another item I need to reproduce as many were ground off or tapped out so that a later venturi could be used.
Back when my dad and I used to rebuild carburetors as a service, we would only get maybe 1 or 2 a year.
I wonder how many of these dual venturi upper and lower castings are still out there?
RENNERS CORNER is offline   Reply With Quote
Old 03-13-2026, 07:37 AM   #13
Joe K
Joe K's Avatar
Like a "Mochi" which appeared on the Avatar for one show.
Joe K
Shudda kept the horse.
Old 03-13-2026, 10:58 AM   #14
RENNERS CORNER
I'm not so sure about that.... I would be interested to know where you read that.
I don't know why that many mechanics would already be working on them in the first 6 months that the car was being built.
What I have read about the DV is that Ford was faced with a potential lawsuit from Stromberg, that is a well documented reason for changing.
I also believe that there would've been Ford service bulletins about this with Ford advising their dealers to replace or be mindful when working on the DV carburetors.
I'm sure at the Benson library there's an Engineering Information sheet that explains this, too bad we can't get back in there....
Old 03-15-2026, 06:30 PM   #15
rackops
rackops's Avatar
I'm sure plenty of them...a guy at Hershey in 2024 had a bucket of double venturi cores. No venturis, but the cores...a lot of them (I picked up a few).
It just all depends on whose collection is being sold off this year...
Member, MARC
Current owner, 1928 RHD Australian-built Phaeton CA4752 "Felicity"
Former owner, 1931 Victoria, 1929 Phaeton, 1929 Fordor
rackops is offline   Reply With Quote
Old 03-15-2026, 08:32 PM   #16
alexiskai
alexiskai's Avatar
That "explanation" appears in Gordon Biggar's book on carbs ("the Rex Reheis way"). He doesn't give any further details, just that one sentence.
Old 03-15-2026, 09:01 PM   #17
RENNERS CORNER
I knew / know both of those guys that worked on that book.
I think like a lot of old timers they always have some bit of folklore / wives tales mixed in with their explanations.
I can't believe that mechanics were breaking that many of them so early on, that's just unbelievable and then to not have any mention of it in service bulletins....
Thanks for the reference though, I'll ask Mr. Biggar about it.
Old 03-15-2026, 09:55 PM   #18
alexiskai
alexiskai's Avatar
What he says in the book is that mechanics would twist the halves of the carb to break them apart, which would crack the venturi. Even if this were true, the solution would have been to tell mechanics not to do that, not to redesign the carb at great expense.
