Old 03-02-2025, 07:57 PM   #1
shew01
shew01's Avatar
Default How can I bend a peep mirror arm without breaking it?
I bought a set of these, but they don’t adjust far enough to see traffic for me.
How can I bend the peep mirror arm to allow easier viewing without breaking it?
Old 03-02-2025, 08:25 PM   #2
Sunny the Model A
Sunny the Model A's Avatar
Default Re: How can I bend a peep mirror arm without breaking it?
if aren't worried about looks so much you can heat it up with a torch then bend it, then you can paint it with chrome paint if need be.
"Ain't but three thangs in this world worth a solitary dime, but A Models, Sweet Tea, and Macaroni Pie!"
Sunny the Model A is offline   Reply With Quote
Old 03-02-2025, 08:39 PM   #3
mleder
You will not be able to make any appreciable bend. The item is made out of zinc die cast (pot metal) it will break. Maybe try to shim the mounting so you create an angle , alternative go to an auto parts store and get a stick on fish eye mirror and place it on top of the existing mirror
mleder is offline   Reply With Quote
Old 03-02-2025, 10:05 PM   #4
JayJay
If you are careful, you can get the travel you need by bending the sheet metal of the mirror back to allow the stem to travel farther. Don't try to bend the arm, it will likely break!
As an alternative, consider hinge pin mirrors. I like them much better than the door clamp mirror you show.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 03-03-2025, 04:38 AM   #5
shew01
shew01's Avatar
Thanks for the suggestion. The previous owner had a hinge pin mirror to go with the car, and he aborted putting it in because he didn’t want it mess up the nice paint job.
The restoration was done in the sixties, and fhat hinge pin is likely going to be a demon to remove.
Old 03-03-2025, 05:26 AM   #6
ronn
just buy a diff mirror that works..............
Old 03-03-2025, 07:36 AM   #7
Y-Blockhead
Y-Blockhead's Avatar
Those peep mirrors are not any easier on the paint. I think a hinge mirror is your best option.
Heating and bending is a really bad idea.
Old 03-03-2025, 08:24 AM   #8
Sunny the Model A
agreed, just take the clamp mirror to the next swap meet. the hinge pin mirrors work well. i put a bug eye mirror from a go kart on the hinge pin mirror bracket. works great and no one is the wiser. since i have a truck the black mirror and black bracket matches and looks normal.
Old 03-03-2025, 10:06 AM   #9
Y-Blockhead
I installed chrome plated Model A Truck mirror (5" diameter) heads on my hinge pin mirrors (from United Pacific) on my Town Sedan. It is amazing what a difference 1" makes.
Old 03-03-2025, 10:47 AM   #10
JayJay
I installed a 4” stick on fisheye truck mirror (from the river store) on my right mirror, it makes a tremendous difference.
JayJay
Old 03-03-2025, 01:58 PM   #11
CarlG
CarlG's Avatar
I've got 6" Convex mirrors on hinge pin arms on both sides of my '31 CCPU. Couldn't ask for anything better.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-03-2025, 02:03 PM   #12
ModelA29
ModelA29's Avatar
File the side that contacts the door on an angle until it gets to where you want it.
ModelA29 is offline   Reply With Quote
Old 03-03-2025, 02:34 PM   #13
JayJay
Shew - with the right tool (https://www.snydersantiqueauto.com/s...hinge+pin+tool) getting the pin out isn't difficult. I have one of these for standard Model A hinges, and I made a set of modified jaws for the larger Slant Window hinge pins.
JayJay
Old 03-03-2025, 03:13 PM   #14
Y-Blockhead
Thing is, over time, the pin gets ridges worn in it (similar to my sketch) that catch when pressing it out. Last ones I did I used a small air hammer to sorta "jiggle" it out. Worked great.
File Type: jpg Screenshot 2025-03-03 at 12.20.47 PM.jpg (6.2 KB, 269 views)
Old 03-03-2025, 11:02 PM   #15
Russ B
Getting a mirror to provide a good rear view can be difficult on a model A, particularly for the right side. For my cabriolet, I ended up making custom mirror arms to solve the viewing problem. It may be an extreme response, but it worked as needed. The wood masters were used to cast new brass arms which were further shaped, fitted, polished and plated. The mirrors available on the market often work on the driver’s side, but not on the passenger side.
Russ B is offline   Reply With Quote
Old 03-04-2025, 11:29 AM   #16
katy
katy's Avatar
Using a coupling nut to extend the mounting stud on the back of the mirror works.
Old 03-04-2025, 11:34 AM   #17
Y-Blockhead
Russ, I remember when you shared that with us. Your mirror arms came out real nice!
Old 03-05-2025, 01:01 AM   #18
Bick in New Zealand
Bick in New Zealand's Avatar
I used those mirrors on my coupe, and was not particularly happy, as they vibrated and moved, and the view was not that great. I ended up buying these, and using the heads on the original arms. I now have great vision on both sides. https://www.ebay.com/itm/11523223928...Bk9SR77j-sisZQ
1928 Roadster (CA67)
1931 Deluxe Coupe RHD
1931 Victoria RHD
Model A's don't leak oil they just mark their territory.
Bick in New Zealand is offline   Reply With Quote
Old 03-07-2025, 09:56 AM   #19
Bob Bidonde
Bob Bidonde's Avatar
Instead of bending the pot metal arm, add a parabolic mirror onto it. I did this to both side mirrors and it works very well to eliminate blind spots.
Bob Bidonde
Old 03-07-2025, 01:47 PM   #20
JRrev
JRrev's Avatar
Don't think that is a peep mirror which usually attaches to a drip rail and is also useless. I'm using clamp-on mirrors from a street rod parts vendor with arms curved more to be able to see.
JRrev is offline   Reply With Quote
