#21 |
Use alkalid enamel, it will flaten out and oxidize in about a couple of years.
#22 |
Instead of using flattening agent use cornstarch
#23 |
Paint it flat black, one coat and let the car sit out side 365 days a year. Won't take long to look old.
#24 |
#25 |
#26 |
Most of my paint work has been with flat military green paint. What they called lusterless. I am sure you can work with flatening agents to get that flat, almost chaulky finish. And, if you wnt with a slightly lighter shade by adding some white to the color and painting the top surfaces with the lighter shade and blending it or feathering it down onto the sides, you would get a sun faded appearance IMO. You got nothing to loose, experiment until you are happy with the results. Primer first, play with the paint and lightly sand or scuff up through the top layer until you get to some primer and just play with it. |
#27 |
rub kerosene on the glossy finish and it will dull out.......
#28 | |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
#29 |
I have painted a lot of cars and to me, fake patina looks just that, fake. Low gloss is easy to achieve with either a flattening agent in the color or a coat of matte luster clear. I have a 33 phaeton with the original top and a repaint from the 40s and I just leave it alone. Pictures in an album.
Good luck. |
#30 | |
#31 |
For sure Gary, there is a big difference between what you describe and someone who wants others to think the car is some barn find. I COMPLETELY understand what you do!
Mike |
#32 |
Thank you Mike! Couldn't resist another repaint adventure before I go back to some boring woodwork in the shop
This is my current avatar tonner that got the H six and the box, running boards and rears from 'Uncle Oscar'. Oscar was pretty rusty from Western Washington(35 years unde a big leaf maple) and as you can see in the background, my avatar truck was from The arid East Side of the Cascades. (Where they grimace and call us folks 'Coasties). This truck was originally black but had been brush painted by one a them hillbillies over there. The next owner started stripping the paint with a globemaster sanding pad in a drill and fortunately did not advance beyond the passenger door and cowl bottom.
#33 | |
#34 |
The rear fender was yellow
I am building a 1939 1 ton express |
#35 |
Too-Mater (avitar photo) was painted with original color using Nason single stage over black epoxy primer. Sanded through the primer and some areas to metal to get close to original looking paint that was on the cab……these areas where original color was in tact it was left and new paint blended into it. Final touch was to spray a little red oxide primer (rattle can style) to look like owner touch up on some panels. Photos in my album…... This wasn’t a 10k job!
Tim Downtown, Ca |
#36 |
#37 |
Yobbo and Vic, excellent work! For this type of work, one needs to forget everything they know about auto body painting and think like a set builder for the upcoming sequel to 'The Grapes of Wrath'. Or maybe 'The Waltons'. anyways.... I think watching John Walton driving his family around in that 1 1/2 ton AA express got me started down this tangled road. God bless him for that.
#38 |
So right-on GB. Pro auto body guys cringe when I tell them how i got to the end finish. I had seen alot of Faux rust and sanding through new finishes, then clear coated that miss the mark. This project was pieced together from an rusty original green truck cab that was a rat condo & the rest of the body came from all over the US, if not painted it would have looked like one of grandma’s old patch work quilts……….
Tim Downtown, Ca |
#39 | |
#40 |
>>I'd like the roadster to have the same sort of patina. Are there any suggestions?>>
>>The sun! Think I'm gonna buy me a high power UV light>>> You might also want to consider a few strategically-placed scratches & dents here & there. |
| Thread Tools | |
| Display Modes | |
