My questions are about the comparison between the 9" and the 9-1/2" clutches
The 9" clutch is just the typical clutch that was used for many years that used a standard Long style pressure plate. See the link. https://fortwayneclutch.com/product/...ew-sku-kt5102/ For the 9-1/2" clutch, the pressure plate looks different than a standard Long pressure plate, but it still appears very similar. See the link. https://fortwayneclutch.com/product/...t8594-1-375_r/ My questions are these: Will the two interchange on the same flywheel or is there a difference in pressure plate bolt pattern? What are the bolt circle dimensions on the two different pressure plates? I have a 9-1/2" pressure plate that I measured the center line of the bolt circle to be approximately 10-7/8". I do not have a 9" pressure plate to measure the bolt circle. Is the 9" approximately 1/2" in diameter smaller? Is it flywheel specific and would have to be redrilled if changing the size of the clutch and pressure plate between 9" and 9-1/2"? Thanks for any help, Roger |
Borg & Beck clutches were 10" but they have six equidistant bolt holes with the next size larger bolt size. They were used on the 1949 through early 1951 8CM Mercury cars which also use the 1 3/8" 10-spline disc drive. A lot of the modern diaphragm type clutches use the old Borg & Beck bolt pattern, |
| Thread Tools | |
| Display Modes | |
