I have a 55 ford Fairlane and need to remove the column shifter and put in a floor shift.
What is the simplest and easiest way to remove the shifter tube from the column ? T he car and interior are in finish paint.If I don't remove shifter tube what suggestions do you have ? thanks |
The main problem will be the shift lever socket.
As far as I know there is no replacement lever socket like a later floor shift car. Stripping everything else from the steering column should be simple. |
Dorf55, this is what I did with my 1955 Ford Club Sedan: https://www.hotrodreverend.com/post/...n-blog-part-11
To each their own, but when I went with the period Hurst syncro-loc shifter I wanted to not only remove the column shift lever but replace with a shaft. I am very happy with the end result.
Red Lion, Pennsylvania Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan! |
Thanks you !
#5 | |
Much nicer install than flat-rating it. |
| Thread Tools | |
| Display Modes | |
