Old 01-21-2025, 10:00 AM   #5
Tim Ayers
Default Re: What head gasket sealant is the best?
Originally Posted by 51504bat View Post
What brand head gaskets are you using and what does the manufacturer recommend? When I installed my EAB heads I used Best gaskets. They recommended a spray on sealer. Permatex I think but not positive. No leaks and I did seal the head bolts using Permatex #2 per the machinist who rebuilt the short block. Again, no leak issues. JMO
That Permatex spray is also a type of glue. If you have plans to remove the heads later on down the road, you need to be mindful of this.
