Hi
I have a 34 fordor deluxe Just redoing some of the car now and rebuilding the factory 21 stud flathead. I want to take a long trip in the car in August,September from Alberta ,Canada to Oregon coast area then to San Francisco then back home. The car will be pretty much stock, to include motor, tranny,brakes and diff. I am planning to install 3.54 gears or 3.25 gears in the rear. I plan on taking spare parts, just not sure what that list might include. And would like to mark or know of a few clubs, shops, etc. along the way in case I run into trouble. Any body running either gear ? What I can expect ? Also I am well versed in mechanics , restoration , repair, but more of the muscle car era, not so much in the 34 or flat head era. And not that well versed in the area I am travelling, other than I have covered some of the same area in a vette several years ago. Any input would be much appreciated Thanks in advance |
If you belong to the Early Ford V-8 Club be sure to take your roster along in the event you need help from a fellow V-8er along the way. Not sure why you want to go to San Francisco, but if it is for simple tourism I would avoid it. I am 50 miles north of SF and I haven't been there since the mid 90s. You will enjoy the Oregon coast route and it's a beautiful drive.
I'd pack all the obvious small parts like fuel filter, plugs etc, but I've been building a trip kit which includes a rebuilt carb and distributor. In the past 5 years I have had trouble with condensors and accelerator pumps, so an extra of those parts by themselves makes easy repair. About a half hour after you pass through Bellingham, take a right turn onto Highway 20 and follow signs to San Juan Islands ferry terminal. We'll leave a light on.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
Thanks I will join up was at one time, wanted to go to Alcatraz
I think they still do tours to Alcatraz. I believe the tours are out of San Rafael. To do the tour you will not need to get into San Francisco. A once beautiful city has turned into a crime infested dump. It's a shame.
You will find the Oregon coast to be extraordinarily beautiful. On crossing into California, you won't see much of the coast due to the roadway being away from the coast for many miles, but still much nicer than the inland route which will be hard on your cooling system and your choice of differential gearing.
Alan |
Grocery store sells gallon jugs of water, cheaper than anywhere else. Get one for you and two for the car, or visa versa.
Enjoy yer day. Tom ![]() Hate can't fix what it started. |
I do Lots on miles in my 33 and 34
a lot away from main areas. On board I have, rebuilt and timed distributor and coil, spare fuel pump, water pump, some generator parts,' condenser.carb gasket set, spare ignition resister most trips never need any, my 34 has the stock rabbit engine,3,34 gears and is a pleasure to tour in. but be prepared for no quick stops as lots of people want to talk. Lawrie |
#10 | |
Awesome thanks so much !!!don’t be surprised if I do , |
Awesome ok thanks……that’s to bad seems like so many bigger places tat is the way
#13 | |
#14 |
I’m not familiar with how good the flatties cool or don’t cool , I am going to put the best rad I can in , kicking around the idea of electric fan ? Thoughts ? Maybe convert to 12:volt or run a 8 volt battery ….any thoughts on that much appreciated
#15 | |
Like your front engine digger pick, I also have one, one I use to run about 38 years ago just restoring it also. |
#16 |
Get the best AAA coverage for towing miles. I have RV and motorcycle, the latter I have. Also get some tow straps after reading this thread.
There will be a lot of climbing so I'd be happier with the 3:54 gearing. https://www.fordbarn.com/forum/showt...ght=tow+straps Glenn
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat’s Notes Techno Source for the 1932 thru 1953 Flathead Ford |
#17 |
The dist and carb type stuff are your biggest risks. Test drive your car, and make sure the water temp is not climbing. If it is questionable before you leave home it will not get any better. Put on a new fanbelt. If ya have a hub puller of any sort throws that in the trunk, with the gallon jugs of water mentioned above.
Adjust your brakes, check the air in your spare tire. I bet you will be fine. |
#18 | |
Thanks |
#19 | |
Thanks |
#20 |
If you do convert to electronic ignition, a spare distributor becomes a necessity (one with points). This has been proven too many times.
| Thread Tools | |
| Display Modes | |
