Old 01-10-2025, 02:08 PM   #1
32Bee
Default 35 Lighting Switch Rod
Is it necessary to put any lubricant on the lighting switch rod prior to inserting
it into the steering column?
32Bee is offline   Reply With Quote
Old 01-10-2025, 02:23 PM   #2
34fordy
34fordy's Avatar
Default Re: 35 Lighting Switch Rod
Possibly a small skim of grease inside and out of the small brass ferule under the horn button assembly, IMHO.
34fordy is offline   Reply With Quote
Old 01-10-2025, 03:49 PM   #3
danliveshere
danliveshere's Avatar
Guys just something else to consider is to thoroughly clean the internal steering shaft as well to help eliminate any friction on the light rod. I believe these should have a film of your favourite oil or grease or lanolin etc because of dissimilar metals between the steel steering shaft and the alloy light switch ( even though they technically shouldn’t touch)!
danliveshere is offline   Reply With Quote
