#21 |
Page on the Liquamatic Drive in the 1942 Lincoln Sales Brochure
Page on the Liquamatic Drive in the 1942 Lincoln Sales Brochure |
#22 | |
TomC750
TomC750 1949 8NV8 Ford tractor 1930 1 Ton White 1941 Mercury Sedan Coupe |
#23 |
I read a little about the Hydromatic transmission and how it did not work out and am in the process of acquiring a 42 Mercury Town Sedan and feared it may have this transmission in it. The seller assured me it is a standard three on the three and I am relieved.
My 46 Packard Clipper has some sort of semi automatic transmission in it as well, but it is a project car and not here at the house for me to look. But some sort of similar set up where you could shift without clutching. But, of courrse, this is the same car that you start by pressing on the gas pedal. |
#24 |
Packard had an electric clutch, my dad used it only once on his 48 Super Eight Victoria convertible because it was fatser to manually shift it by clutching it himself. He LOVED SPEED & Packards . Drove them till 1958 when he bought a Lincoln. Drove lincolns the rest of his life and was a died in the wool FORD Man.
#25 | |
Alan |
#26 |
I've got a 46 Packard Clipper awaiting it's turn in the shop that also has some sort of semi auto trans that I was told you could shift on the fly with no clutch, but still needed to shift. Don't know what the Packard trans system was called as the car is not here at the house. But, this is also the same Packard that starts by turning the key and then steppin on the gas pedal to energize the starter. |
#27 | |
Alan |
#28 |
That Transmission used to be at the California Auto Museaum in Sacramento Ca
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
#29 |
Brendan, it’s not just the transmission, it’s also the block which has a unique bell housing matching only the liquimatic.
Alan |
#30 | |
The rest of the auto makers were desperate to develop some kind of automatic shifting transmission after GM brought out the Hydromatic. All sorts of weird setups based on self shifting three speed manual transmissions were offered by many makes (Mercury / Lincoln, Hudson, Packard, etc.). The Liquimatic was simply Ford's last minute half-baked attempt at offering something. The self shifting feature ended up with both second and third selected at the same time, with an over running clutch between the second gear and main shaft of the transmission. This over running clutch failed frequently and doomed the transmission design. A much better explanation can be found in Dave Cole's articles in the V8 Times, available as PDFs on USB from the V8 Club website store. |
| Thread Tools | |
| Display Modes | |
