Old 12-29-2024, 10:00 AM   #1
air1force1
air1force1's Avatar
Send a message via AIM to air1force1
Default 39 Ford Standard coupe
Hello, does anyone know if the 39 standard hood, when opened would remain open without a prop? Mine will not, and not sure if it is missing springs. Currently i use a rod to prop open, but this is risky on windy days.
Thanks,
John
air1force1 is offline   Reply With Quote
Old 12-29-2024, 10:36 AM   #2
Planojc
Planojc's Avatar
Default Re: 39 Ford Standard coupe
Mine stays open, no prop. You may need new springs.
Planojc is offline   Reply With Quote
Old 12-29-2024, 11:00 AM   #3
Kube
Super Moderator
Kube's Avatar
Thanks,
John
No prop rod required.
Be aware that the reproduction hood supports are NOT correct even though they are advertised as such.
Rebuilding yours is the best path forward. Usually all that is required is removing the rivet at the pivot point, welding up the holes (sure to be elongated) and redrilling / reaming to the correct diameter.
Find a rivet of the correct diameter at your local hardware store, cut it to the proper length, about 3/16" longer than the total width of the support levers, insert and peen over.
You may swap out the springs if you really feel the need but, in my experience, the elongated holes are the root casue of the supports not doing their job.
Old 12-29-2024, 11:13 AM   #4
TJ
TJ's Avatar
Thanks,
John
If you have the V-8 Club's 38-39 book check section 4 beginning with page 4-44. It explains with photos the difference between the hoods and hinges of the 38 deluxe and the 39 standard. On your car you could be missing the springs that are attached to the hinges that hold the hood up in the open position. If you have the springs they may have become weak over time and no longer function as intended. If you don't have the book it is a wealth of information for the 38-39 owner. You can purchase it on the Early Ford V-8 Club website.
Kube is also correct about the holes at the pivot point being worn.
Old 01-01-2025, 01:02 PM   #5
air1force1
air1force1's Avatar
Thank you. Ordered that book today.
Old 01-01-2025, 10:23 PM   #6
mercman from oz
mercman from oz's Avatar
1939 Ford Standard hood mechanism
Old 01-01-2025, 10:28 PM   #7
mercman from oz
1938 Ford Deluxe Hood Mechanism
The 1939 Ford Standard Hood Mechanism arrangement was a 100% improvement over what was used in the 1938 Ford Deluxe.
Old 01-01-2025, 11:30 PM   #8
farmertom
farmertom's Avatar
Hmm,this hood prop looks to be very much like the oe hood prop on my '37 sedan which i thought was a one year only part. Tom.
farmertom is offline   Reply With Quote
Old 01-01-2025, 11:36 PM   #9
ford38v8
ford38v8's Avatar
'37 - '38 hood props are identical.
Alan
Old 01-02-2025, 12:09 AM   #10
Clem Clement
Clem Clement's Avatar
I used a Model A brake rod attached at one end. Then inserted it in 1/2 id rubber tube so it did not rattle.
Old 01-10-2025, 03:02 PM   #11
air1force1
air1force1's Avatar
Hi, I got my book today, and mine is missing the assembly with springs. My dad built the car several years ago, and can't say why they were omitted on the build. It's a restomod, and not much original on the car. When spring comes I will look to see of the holes are still there.
I'm going to visit family in March. I will look to see if the hinges that have the springs are in the parts left over.
Thanks,
John
Old 03-16-2025, 08:20 AM   #12
air1force1
air1force1's Avatar
Angry Re: 39 Ford Standard coupe
Hi all. After looking at my 38/39 Ford book, seems the 39 standard coupe had 2 hood hinges, but only one hood support (drivers side). I just gained access to my car (snow piles) and only have mounting location on drivers side.
Looking at supports on early ford, it looks to show two? Perhaps I'm interpreted it wrong?
I'm sure people on this forum will know. Thanks in advance!
Old 03-16-2025, 09:55 AM   #13
Kube
Super Moderator
Kube's Avatar
There is but one support and that is on the left side. Be aware that the support is different than the '40. You can't simply remove the lower "leg" from the '40 support to fit a '39 standard. It won't work. Plus, the reproductions are wrong and won't work either.
