what companies sell a flywheel for the 239cu in Flathead. I see th at Speedway. Anybody else.
There's some on Ebay but, where ever you buy, make sure you have the correct tooth count. I sent you a PM.
Since 239 CI engines came out in 1939, there are two different types. The pre-8BA and the 8BA types. The starter ring mounting is different between the two so just be aware of which type is needed. I've seen the aluminum types with the steel insert so there is that difference as well.
Centerforce makes an 8BA flywheel and diaphragm pressure plate.
#5 | |
..... and they are a thing of beauty!
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
| Thread Tools | |
| Display Modes | |
